Anyone have experience with this header?
591 Views 18 Replies 7 Participants Last post by  SightsSet
Been looking for an aftermarket option, but haven't been able to really find any these days. Looks like no one carries the OBX or Pacesetters anymore, and the Greddy/Trust pop up on eBay from time to time but I'm not sure they're worth the $1400.
Found these generics on eBay. Looks to just be a Pacesetter clone. Anyone have any experience with them? Would have to relocate the O2 bung closer of course, and the 2" collector is a bit weak, but could probably modify the 2-1 section into a larger collector. All in all, worth the money over the stock manifold? It will be paired with a full exhaust.
1 - 19 of 19 Posts
There look like some good possibilities there. Make your own collector out to 2.5 or 3" and build off that. Check the welds at the flange and look into ceramic coating it too. Also like you said relocate the O2 sensor bung to a better location.
The way that header is I wonder if a dual 2" side by side exhaust with twin tips would be do-able?
That ebay one looks pretty much just like the one I got for free from a friend. Hard for me to say whether the header alone is worth it, because I added a larger exhaust and freer flowing muffler and advanced the ignition timing 2 degrees all at once. Collectively, yes notable improvement. Probably not more than 5 or horsepower, but the throttle response was greatly improved and for me that really enhances the driving experience.
Reactions: 2
Honestly, improved throttle response alone would be worth it for me. Haha. Mainly concerned about build quality since it's a no name, but I hear the Pacesetters are hit and miss anyway.
I didn't have any issues fitting mine. Not sure what car mine was on before, was likely a Cressida though. Someone had already moved the o2 sensor, but I needed to extend the wire anyway. No problem.
No issues with the build quality. I don't expect these to last a really long time anyway. I don't drive the car more than a couple times a week, and I'm fixing to swap in a 1UZ next year anyway.
No hesitation recommending these to anyone. Shoot, you can have mine for the price of shipping once I take them off
Throttle response is a very nice thing. When I daily drove my Supra 25 years ago it had a tiny single outlet muffler and had trouble getting out of its own way. With the Raptor Racing header and Raptor 2.5" magnaflow exhaust it moves, snappy throttle and sounds good too.
I do wonder if a 3" exhaust would make a bigger difference.
I've been trying to find any info I can on 2.5" vs 3" on stock to lightly modified engines, but can't seem to find much in the way of definitive answers. On one hand I feel like 3" should be fine due to most of the scavenging taking place in the header, but on the other I feel it may be too big and allow for build up of gasses/air and actually caused the engine to struggle a bit forcing the extra volume out. I honestly don't know. Would love to hear other people's input, especially if you've used 2.5 vs 3.
I remember when I had a Nissan 240SX I saw someone dyno a 2.5 inch vs a 3 inch exhaust on a KA24DE engine and the 3 inch made more power pretty much everywhere. So, a big 2.4L four cyl benefitted from the bigger exhaust, not a big stretch to say the 2.8L six will too. The KA has a long stroke though, the 5M is a bit closer to square so maybe won't benefit as much.
However, with these old and relatively small NA engines, the difference in output between a 3" and 2.5" is pretty small. Like, probably less than 5 horsepower at best. Probably not worth the extra weight and noise to go with the 3"
A 2.5" with a resonator and a good muffler will get you a few more horsepower and better throttle response and a nice exhaust tone, without it being too loud and boom-y.
Just note that a Pacesetter style header will sound kinda buzzy with a 3" exhaust, like trying to play a tuba with a trumpet mouthpiece. It will also set up some annoying drone at mid-range with a 2.5". That's why the engineers don't just put headers and big pipes in from the factory. Everything is a compromise and you don't get that much benefit - literally looking for tenths of a second performance gain. I installed a Pacesetter back in the 90s and then spent over $3,000 in the space of a couple months trying over and over and over...... and over...... again to build an exhaust system that I could live with. This was while still using the mk2 as daily driver. It was literally like trying to build a musical instrument without knowing even how to read sheet music. Wound up back down to 2 1/4" with a big resonator in between the cat and muffler.
Since your mk2 is not likely a daily driver anymore at this age, maybe you are just building a toy for autocross or such, you can do whatever your ears can tolerate. Just fair warning, go too big and you may not like what you hear, especially behind a long-tube header like that.
I've seen a lot of modified cars for sale that languish online for years because the seller spent all their money on an ear-piercing exhaust system, can't afford to do it over, especially knowing its kind of a risk whether it will sound any better and nobody will buy it for the same reason. So whatever you do, don't cut up, discard or lose any of your stock exhaust system. That way if you can't stand the Pacesetter clone, you can at least put the stock system back until you decide to try something else, or if you decide to sell the car.
Reactions: 3
2
Drone can be a terrible thing. I built an exhaust on my Jeep 4.0L 20 years ago using baffled muffler with no packing - Raven, Midas' house brand and at 115Km/h, normal highway speeds around here I couldn't hear the radio or the phone but could hear the fillings in my teeth. I added a Red glass pack in place of the tail pipe and that calmed it down perfectly.
It is hit or miss. That's why I am glad I got the Raptor Racing stuff. George has done the trial and error and found a combo that doesn't tend to drone. According to him mine is the louder of the two exhausts. Even though it has a resonator and a muffler. It stays quiet, when you hit it past 4000RPM it sings but you CAN hear the radio and phone and my filling thanks me.:D
Bumper Hood Automotive exterior Musical instrument Electric blue
Tool Auto part Font Electric blue Rectangle
This was one of the prototype exhaust systems. The later systems have a dual output muffler. I also have no idea why there is orange silicone on there. (Because Prototype??):LOL:
Reactions: 3
The RR header would be great, but as I understand it they are no longer in production and I've yet to see one pop up for sale secondhand.
I have this exact unit up for sale. PM me if interested or shoot me a FB message.
Long story short... the build quality is not great. The welds were not complete. I had to take it to a shop to have them fill in and clean up the china booger welds.
The flange itself is somewhat warped too. Not sure if this was from the welding shop not clamping it down properly when applying heat, or it came this way from china when it was built.
Also of note... it does not have a provision or bracketry for the alternator support like the oem cast setup does.
Either way, the shop I have basically restoring my 82 didn't feel comfortable installing it due to the alternator support. If I decide to keep the 5m going, I am likely going to be going with the Greddy... as much as it sucks paying $1500+ for it CDN.
Will be making a for sale post soon. I think I have 500$ now into this stupid header. I'm open to offers if someone wants to straighten it out and run it. I'm sure it will look and sound great.
I don't remember any braketry connection on the Raptor header on my '84. Is that a 1982 specific thing?
Reactions: 1
Kinda remember for the PaceSetter ?? or headers in general you have to modify the header for the alternator or PS support bracket to bolt up??
Reactions: 1
2
No issues with my Raptor header:
Motor vehicle Vehicle Auto part Automotive fuel system Gas
Automotive tire Hood Automotive fuel system Motor vehicle Automotive exhaust
Do you have to notch the other header to clear the bracket ( the one with the shiny bolt head) ?
Reactions: 1
4
None of the aftermarket headers have provisions for the power steering pump support bracket.
The tubular header material is not strong enough to resist bending.
I don't know if anyone running headers without this bracket have power steering pump drive belt issues. It helps keep the power steering pump pulley in alignment with the drive belt.
Bumper Automotive tire Automotive exterior Gas Auto part
Power steering pump support bracket. Photo by BillyM
Wood Bumper Bicycle part Musical instrument Metal
Stock exhaust manifold - Support Bracket Mounting Point
Automotive tire Motor vehicle Automotive design Rim Automotive lighting
Vehicle Motor vehicle Automotive design Automotive tire Automotive exterior
Josh brings up a good point, but I can't imagine that this is a common problem. If it were, no one would run headers.
Has anyone had this problem?
Dale
I forgot about that bracket. I found it after I had put my car away for the winter and wondered where I took that from.
You are correct, no provision for that bracket on the aftermarket headers. I too wonder if it will be an issue. Probably not with the millage most of us put on.
I'd imagine it would fairly easy to add that bracket attachment point.
1 - 19 of 19 Posts
