1 - 8 of 8 Posts
I just bought an 82 P-type (formerly scottevil's). Under the hood, on the passenger's side behind the airbox I see a dangling white connector that looks like it should be somewhere.
I see other loose yellow connectors, but I'm guessing those are for diagnostics? BTW, the headlight motors do not work, is this related to problem?
I think thats the headlight relay connector. It bolts to the passenger side apron
you found that you are missing a part !
yes the headlight relay is normally just opposite to that lamp,
Still working on the headlight retractors. I replaced the underhood relay but more issues. According to the TSRM diagnostics, I have a bad diode in one of the headlight motors, and my retractor control relay is bad (blue box under dash near steering column). Also my fusible link is blown. Eeeek.
1 - 8 of 8 Posts
