So my sending unit is done... ribbon is completely disintegrated. I have posted want ad's on here an FB, no replies yet. Ebay, nothing.
I read in the TSRM for diagnosing the sending unit that resistance should be 3-110 ohms (empty-full respectively). After searching for a sending unit that would match these readings I found that a 1986 toyota corolla (AE86) is the closest possible find. It even looks identical. It operates on a 0-110 ohms scale.
Right now I can only see one problem, it may not fit on the tank - alignment of the mount to the screw holes. Even with the ohm range being out by just a bit, I would assume that the needle would just simply read a bit more than full on a full tank. I mean its only ~3% of the entire range of the actual gauge.
Has anyone tried doing something like this? I would much rather keep things stock, and will try and be patient with my ad's... but this seems like it would work.
Help.
Help.
