A while back, I watched an episode of the TV show Wheeler Dealers, which featured Mike and Ed refurbishing a Triumph TR6. I mostly watched this for the section where they repaired the fuel tank, and was furious when they showed the repair, but gave no details as to the guy who did it!!
However, there was something else in this episode that caught my attention - after replacing the valve seats, they changed the coolant, and instead of standard water/glycol, they used a proprietory mixture that contains zero water.
I've looked it up, and it's Evans Waterless Coolant.
http://www.evanscoolants.com/index.html
What really made me take notice was when Ed pulled the radiator cap off the engine while it was running (and apparently hot) - because it contains no water and boils at 180'C, the cooling system is not pressurised (or at least, nowhere near that of conventional water!!). Now this sounds a great deal safer, and better for the engine for a multitude of reasons - no water to erode the innards, no pressure to blow up the rad (!!), never needs replacing so lasts the life of the engine... it sounds like quite the silver bullet.
Sounds like.
It does make sense that using something waterless would be good for a car, particularly a Supra! But obviously I'd like some opinions. As Dragon is currently devoid of coolant (grr!), I want to know if anyone thinks it's worth the (admittedly quite considerable) expense. I found the Recommended Coolant thread and will go with Toyota OEM red coolant if I can get it, but this represents a great opportunity to fix something 'once and for all!'
Sounds like.
