Make a reasonable offer on anything you want. Make it your offer before shipping costs. Shipping from 30557.
From a 5mge:
intake and exhaust cams
upper and lower intake
afm
air filter "casing"
valve covers
crank
power steering pump. whines.
cam gears (both)
distributor
front plastic cam gear cover
head
lifters
body wise, all parts from a blue '84
headlight covers
corner lights (not cracked, busted, etc)
grille
header panel (with washer nozzles, no emblem)
hood, not bent anywhere, a little rust but nothing serious
drivers side P type fender
3 flairs, I sold the passenger front to a local guy
'84 tail lights
a set of louvers, I have to find the bottom clips, theyre here somewhere
windshield wiper cowl
driver and passenger door (one has a cut harness, I needed it)
interior and other random junk:
rear hatch covers
climate control panel
rear 1/4 panel lights, perfect
rear quarter windows
"thing that holds the tag between the tail lights"
2 good rear shocks, rode smooth
4 l-type wheels, 2 have been painted, 2 are mint. you could remove the paint.
rear arm rests
front ash tray
shifter knob, 5 speed
drivers side lower dash
rear speaker brackets
sunroof switch and surround
headlight motors, worked perfectly
gas tank
fuel pump
manual transmission cross member
flywheel
From a 5mge:
afm
air filter "casing"
valve covers
crank
cam gears (both)
distributor
head
lifters
headlight covers
grille
'84 tail lights
rear hatch covers
rear arm rests
front ash tray
gas tank
fuel pump
flywheel
