1 - 7 of 7 Posts
Ok so here is what im dealing with every MORNING (morning only have not delt with the cold days yet) from a cold start the tranny will not shift gears for a few minutes after that it shifts fine even when starting it after school when its been sitting for a few hours. I took it to autozone and the guy said it sounds like the the transmission selenoid. What do you guys think?
what year is it? your nick say 82 so ill assume is a 82 right?
not really sure about the tranny, but i guess the 82 didnt have any solenoid, maybe im wrong, i know i had a 85 tranny but wont work in a 82 or 83.
found this at wikipedia.
A43D
This transmission model is not electronically controlled. It is instead controlled by throttle position and also by a governor.
Applications:
* 1981 Toyota Celica Supra
* 1982-1985 Toyota Celica XX 2000G/S turbo
* 1982-1985 Volvo 240 2.1L Turbo I4 (AW71)
* 1985-1990 Volvo 740 2.3L Turbo I4 (AW71)
* 1985-1990 Volvo 760 2.3L Turbo I4 (AW71)
* 1985-1990 Volvo 760 2.8L V6 (AW71)
* 1987-1989 Volvo 780 2.8L V6 (AW71)
* 1985-95 4x2 Toyota Pickup with 2.4L I4
Gear ratios: 1st 2.452 2nd 1.452 3rd 1.000 4th 0.688 Reverse: 2.212
[edit] A43DL
Four speed automatic with lockup torque converter
Applications:
* 1983-1985 Toyota Cressida
* 1982-1985 Landcruiser
* 1982 Celica Supra
* 1990-1992 Volvo 740 2.3L Turbo I4 (AW71L)
* 1991-1997 Volvo 940 2.3L Turbo I4 (AW71L)
[edit] A43DE
Four speed automatic with lockup torque converter and electronic controls
Applications:
* 1982-1987 Toyota Cressida
* 1983-1986 Celica Supra
* 1992-up Suzuki Sidekick (4L30E)
* 1992-1998 Volvo 960/S90 (AW 30-43LE)
Check the fluid level?, let it warm up 5 min. in neutral w e brake set. then pull the dip stick wipe it clean, then stab it back in pull and make sure its between the lines or dots.
If level is ok, Your best bet is to take it to a tranny shop. and repair it before more damage occurrs.
1 - 7 of 7 Posts
