You can source on Megazip, IF I can find the parts lists I provided for another forums owner I'll post it. He recently rebuilt his Auto shifter.
Swivel, Connecting Rod (For Column Shift), Toyota 33723-22010 | US $6.50 | 1 pc. | US $6.50 | |
New Genuine Part, Toyota 95381-02020 | US $0.40 | 1 pc. | US $0.40 | |
Spacer (For Control Select Lever Support), Toyota 94613-10800 | US $0.65 | 1 pc. | US $0.65 | |
Nut(For Steering Damper), Toyota 94110-41000 | US $0.97 | 1 pc. | US $0.97 | |
Bush (For Transmission Control Rod), Toyota 90999-99017 | US $4.23 | 2 pcs. | US $8.46 | |
Bush (For Floor Shift Control Shaft), Toyota 90385-14002 | US $2.94 | 2 pcs. | US $5.88 | |
Grommet (For Transmission Control Rod), Toyota 90480-17177 | US $1.90 | 2 pcs. | US $3.80 | |
New Genuine Part, Toyota 91619-61228 | US $1.30 | 2 pcs. | US $2.60 |
here are the bushing #s that look like could be wear items...
90999-99017 X 2 each
90480-17177 X 2 each
90385-14002 X 2 each
33723-22010 X 1 each
Arch
Thank you AJ!!You can source on Megazip, IF I can find the parts lists I provided for another forums owner I'll post it. He recently rebuilt his Auto shifter.
