Bob,
Someone is already checking into the CelicaXX hatch sticker. There was a thread recently within the last 2 days... Time to use that search function.
Nose badge: VERY CAREFULLY with a flatblade screwdriver... it can be pry'd off..
B-pillar badge: Pretty easy to do, but it's a tiny bit more involved.
1. Undo giant bolt where the seatbelt is attached to the b-pillar. Can't remember the socket size needed. 90% of the time it loosens, the other 10% it's on rediculously TIGHT!!!
2. Small screw to undo on the trim piece where the belt goes behind the side panel.
3. Pry off/slide off plastic interior panel for b-pillar.
4. Using a deep 8mm socket, loosen the 2 nuts that fasten the black trim piece to the b-pillar.
5. Pry trim piece off b-pillar.
6. Look behind the trim piece, it's held onto a metal bracket via several round clips. You only need to remove the 2 bottom ones via flablade screwdriver.
7. Gently lift off metal bracket. You'll notice that the small badge is held in place by 2 tabs. Pry them up & carefully push the badge out of the black trim piece.
8. Assembly is the reverse....
Have fun.
