I originally got the car from My cousin. It had been sitting for 10 years in the woods. He finally towed it to his house, and I came to get it.
This is how I got it...
I immediatedly went to work. It was missing the intake, the injectors, it was put together outta time, had no intake piping, no afm..., no dizzy...
I dug around in some engine parts behind my cousins house and found the intake burried in the mud and dog shit. I cleaned it and painted it, painted the valve covers, found the dizzy somewhere in his house.
The inside was piled with junk and full of rat terds.
Before
After(best I could do not having a vacuum that day.
I then went to the junk yard, autozone, and got everything needed to make it run. So I got it running, and washed the car hardcore.
Yeah, I know some lines are routed wrong. lol
Then I heard a valve tap before I ever even drove it, so, frustrated, I sold my GTP.
It previously recieved a built motor which failed due to a shotty timing belt tensioner.
I got a running 6mge
After Install
Ok, So I have a good running 6mge in my car right now, drove it a few times, pretty mean.
The block is studded, upgraded with a modified 81 Chevy alternator, Mechanical fan delete, p/s delete, a/c delete.
So I got my hands on this stuff today, and my friend has more where that came from.
This will be a track only car, well mostly.
I've read a lot, and everyone uses these FMU's, but i'm leary of them. I want plenty of fuel at 6000 rpms, not to be wondering if my fmu is working properly, or worried i might bust a 30 year old fuel line from too much pressure. So nothing less than 440's for my supra.
Any opinions will be appreciated, and Thanks for reading.
My 160LPH Bosch fuel pump.
New used GM alternator
Block Stamp, proof of 6m goodness.
Freshly painted turbo exhaust manifold.
Out With The Old & LAME
Could see a benefit from a portmatch.My guess is thats about an 1/8" lip.
In with the New
UPDATE
Just got this Downpipe in today. The bolt holes need drilling out on the flange but appears to be perfect fit otherwise, and plenty of ground clearance, and is solid 3 inches mandrel bent and I am very impressed with the quality for only $102.00 including shipping. Picture looks like its smaller in the flex section, but its not, its a very nice pipe.
http://www.ebay.com/itm/7MGTE-MK3-MKIII-Downpipe-86-92-Toyota-Supra-Turbo-3-/130557726226?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e65d8ce12&vxp=mtr
Also got a Sunpro air fuel meter. Yeah its not the greatest and a narrowband, but will at least let me know if im uber lean. Gonna try and take it for a drive this coming week.
3" CX racing downpipe.
I temporarily mounted a cheapo a/f gauge so I could tell what was going on during my idle adjustment, I was in a hurry, so its installed via Gorilla tape.
Got this intercooler for 10 bux, gonna install it tomorrow or the next day
With the Idle mixture screw on the afm I was able to get the idle leaned out, I have the screw turned all the way lean, and the afm leaned 3 or 4 clicks. However I still haven't took it for a drive because the sock in the fuel tank is clogging up and killing my fuel pressure, so i gotta drop the tank again for a good derusting.
I believe this setup will be just fine with the 440's and stock ecu and afm mod boosting at stock psi. Running the wastegate boost reference from the intake instead of the compressor to eliminate the pressure loss from the intercooler, and may run a boost controller so i can turn it up in case of emergency, but I'm not turn up past 10 psi on the stock timing curve. Will keep updating. Lookout for new pics and video coming soon.
UPDATE!!! Aug 2016
Purs like a kitten warmed up
CURRENT MODS LIST:
True 6mge swap,
head studs,
ACL Bearings
440cc 7mgte blacktop injectors & clips,
dual fuel pumps in parallel,
96 Toyota 4 Runner Sr5 fuel filter
81 GM 3 Wire Alternator, converted to one wire.
7mgte factory turbo manifold
CT26 turbo
2 1/4"- 2 3/8" intercooler piping hot side, 2 3/8" - 3" cold side, 7mgte 3000 pipe.
AFM leaned out
Power steering delete
A/c delete
Gutted
Sound deadening mats delete
Cold start as extra injector during scramble boost
3" boost/vac gauge
Fuel pressure Gauge
Timing at 10 *
93 octane
Sunpro narrowband A/f meter
3" Downpipe
HKS Front mount intercooler
Scramble boost
Boost reference taken post intercooler
84 ECU
3" short ram intake
Fuel cell
Before
After Install
In with the New
UPDATE
UPDATE!!! Aug 2016
CURRENT MODS LIST:
True 6mge swap,
head studs,
ACL Bearings
CT26 turbo
AFM leaned out
A/c delete
Gutted
3" boost/vac gauge
Fuel pressure Gauge
Timing at 10 *
93 octane
3" Downpipe
Scramble boost
84 ECU
3" short ram intake
Fuel cell
