81 - 100 of 104 Posts
As the old saying goes....."There's More Than One Way To Skin A Cat".......which was really about CatFISH, and not the little furry creatures that hack up hairballs.
I don't have any way to weld or braze things back together, so I'm taking the "Cut-and-Bend" approach.
I mad the first cut with the Dremel, rebent the clamp, and now it snuggles down to the battery:
From the top:
The 1st cut I made was probably a bit wider than it has to be, but I'm doing this "by ear", so it aint gonna be perfect, just an example of what can be done with a MK-III clamp.
Back to a bit more Dremel-and-bend work!
Better catfish than cats !
Looks like the battery is snug inside the L-bracket with your modification, just need another little bend to get the bolt hole lined up...... or just use a long bolt to compensate.
From what I've seen so far this looks like this will almost certainly the best alternative for MKII owners needing a hold-down (myself included).
Annnnnd..... It Fits!
Four cuts, two bends, and it fits!
Is it pretty?
No, not yet. A more careful placement of the cuts, possibly using a thin saw blade instead of that meat axe of a Dremel I used, and a little more care in bending it, and I think it would be quite passable.
Does it work?
YEP!
Nice and snuggled down to the battery.
A little file work to smooth the edges, maybe a bit of JB Weld to fill the cuts, and a shot of satin black paint, and it'll look a bunch better than it does now.
Nicely done Sir, that looks pretty darn good ! Those small cuts aren't very noticeable, and don't look bad anyhow since they're symmetrical and clean.
I'm glad this worked. It looks like factory too, that's what I want for my car. As long as Toyota keeps these parts for sale we all have a good solution to a loose battery now.
Thanks for trying this, especially since you had the MKII part and didn't need to.
I guess I need to contact the dealer and get one on order for myself !
Yeah, watch there be a run on MK-III battery clamps now!
After I have dinner, I'll take the uncut part number 74404-14310 that I have, take some pix and edit them as to where I put the cuts, and post them.
This was real "Quick-and-Dirty", and I'm sure with some careful placement of the cuts and care in bending, it would look really nice.
And I can put my OEM MK-II bracket back in the plastic bag, and save it for the guy doing a "Pebble Beach" restoration.......
I would not have cut the MK3 part. I would have made from a rubber block a spacer in an L shape to fill the gap between the new part and the battery. I've done that in the past for lower hight battery, and it holded very well.
Hi Jim,
How tall is the battery? Are they all this size now a days? I would be tempted to find a pad that fits inside the battery tray or under the battery tray to bring it up to the height of the hold-down. If it was the size of the base of the battery it might not be visible.
I know that when I replaced the OEM battery years ago the batteries were a different size than the old one. Is it possible that some batteries are a little taller and might fit without needing this modification?
Dale
It's hard to tell with pictures, but it looks like if you put a bolt through the Mk3 tie-down the angled portion of the tie-down would lie flat on the sheet metal. The problem would be that the tie-down would sit about 3/8" too high to touch the battery.
But, what if you raised the battery instead?
Would a rubber mat cut to fit under the battery bring the top of the battery up so that it snugs up against the tie down?
It's possible that the angle of the tie-down in this picture isn't the same angle of the sheet-metal that it mates to, but in this picture it looks pretty close.
Just interested in seeing if one could avoid having to cut or modify the tie-down at all.
Oh, and of course check to make sure that raising the battery doesn't bring the terminals into contact with the hood. That could be an expensive mistake!!
Good thinking! It also may be possible to bend the sheet metal were the front mount goes.
Then, the jack up method may be a solution.
Thread a long bolt into the mounting hole and use a socket and a long extension to bend it more horizontal.:thumbsup:
I'll say NO. The MK III ones can be modified to WORK,otherwise the magical 3D printer's boys can help. If you can find a used one,I'll buy it. It may help to MAKE a new 3D printed one.
It will fit into a small priority box.(I think).
If you have an old and tired battery,pull it out and clean and treat the battery tray to remove the rust and corrosion. The consequences of a leaking battery are horrible,to say the least.
The 'hold down' is important.
Make one or find a used one.
The frame rails will be horribly damaged if the battery (that contains acid)is, or was leaking.
The more banging around and deep discharge will damage that (damn) old school storage device and kill your alternator.
The GEL cells are a little better, but it's not a cure all for battery problems and long life.
Optima batteries have good and bad reputations.(Jelly rolls).
The lead acid flooded ones do not tolerate vibrations so well. They short out their cells very easily and KILL your alternator.
If the battery in your car flops around,there will be trouble. Yeah,the warranty will still be good.
I worked for Sears Automotive and we never faulted a lack of a battery hold down to deny a warranty claim.
Like I said,I'll buy a USED battery hold down for a MK II,if you can find one. +++++
So will many other members of this forum. They are special.
<a href="https://imgur.com/O72Gn8j"><img src="https://i.imgur.com/O72Gn8j.jpg" title="source: imgur.com" /></a>
I have a bit of corrosion going on+ rust.
Keep your Supra alive and happy.
Need more parts? We may have them for your build. I have been bailed out a LOT of times.
We are a community of MK II owner hoarders that know that parts are difficult to find and we collect them. Some owners have a LOT more space to store their parts than I. So envious.
The forums? No, but he still works at the same place and can be contacted the same way. He still keeps up with parts availability for our cars and many others, excellent to deal with if you need to order any factory parts at all.
