1 - 13 of 13 Posts
Ok, after much deliberation, i finally decided on a route to take the body of the car. I am going to remove the side mouldings and fill them in, and I am debating on shaving the rear hatch lock and the door handles still tho.
Has anyone done this, and how did it turn out? Pics if ya have them.. :)
Also, should I actually cut the chanel out of the metal and weld a piece in where I remove the mouldings, or would bondo be ok?
Haha, funnily enough I've done this, wll, I'm in the process of doing it.
I used the epoxy putty listed on the PPC (POR15) website, and its strength is something I hope holds out as people had suggested i weld the holes up...but then I saw this and thought i'd give it a go.
Don't have any pics of it at the moment though sorry.
fiberglass is strong enough to cover little holes like that. Don't do just bondo to cover a hole thats any larger then a few mms. I wouldn't recomend welding them. Obviously thats the strongest solution but welding in the middle of body panels usually cause the meta to shrink, and then you have a real mess on your hands. It might not be a bad idea for the door handles though.
Avp23 said:
ive been doing this for years now. i use metal bondo mixed with fiberglass at the same time before it drys.
:drinking:
can ya give a bit more detail on this? Did you lay Fiberglass then bondo, or actually mix the fiberglass strips into the bondo?
I did the rear hatch, and all four arches are bonded onto the car. I dont think the door handles would be a good idea though incase of a battery failure. I believe my man welded up the holes and blended in fine filler on top.
Check out my pics.
Pat
http://photos.yahoo.com/pathipkins
Yes it is functional. I can't say for sure if there is any real improvement but if you fit a induction kit of some sort in must help some. I have a ram air induction kit on mine and it made a lot of difference. The weather is perfect for this setup at the moment, sunny days and an east cold wind.
Pat
Registered User
Re: this is my car
Avp23 said:
http://www.cardomain.com/id/avp23
check out what ive done
:drinking: :snipersm: :2gunfire:
i still love those, lol
How are you planning to handle the flares where they are molded around the trim pieces?
I've been considering just pulling the trim and leave it at that, but IMO, it just looks like ass with the gaping holes in the flares....
Mike
1 - 13 of 13 Posts
