1 - 9 of 9 Posts
Hi, I just sold my car and now I have some stuff I've been working on for sale.
This is a ma60 rear subframe who is customised to fit a ma70 supra differential, ma70 rear hubs and mercedes AMG C63 brakes.
I took a piece out of a ma60 rear chassis and used it as a jig to mount the MA70 differential.
I took the trailing arms and made a jig for them as well, then cut away the "stubby" axels and replaced them with custom ma70 bearing retainers and ma70 hubs.
The geometry of the subframe is the same as I have not moved any stock mountings, just strengthened them and added a camber kit.
The swaybar I used to make the swaybar mounts is an ADDCO swaybar, that one is sold beacuse i borrowed it from my car when building this.
Swaybar is mounted in a way that it does not interfere with CV shafts.
There is no parking brake, you have to mount extra p-brake calipers if you want.
All this is 100% bolt on without body modifications the only thing left to do is to order custom cv shafts, I have cut one of the ma70 shafts to measure.
As for front i have mounted the brake discs to mitsubishi starion hubs, you need adapters made for the front calipers to mount to ma60 front struts. I haven't made these yet because I dont know if I sell the brakes separate.
You need to use 18" wheels to make room for this brakes.
I want to sell all of this as a kit:
Custom subframe
Custom trailing arms with new ma70 bearings.
Differential (some sort of LSD, both turns the same way)
Rear half ma70 drive-shaft
mockup CV shafts from the same ma70 (one is cut to the right lenght for meassure)
Starion front hubs 5x114,3, new front bearings.
Full Mercedes AMG C63 brake kit 2x360mm front floating discs with 6-pot brembo calipers, 2x330mm rear discs with 4-pot brembo calipers.
Goodridge braided brake lines.
Price: offers, I dont really know what to ask for this. I have paid over $3000 for just the parts alone.
These parts are located in Sweden, I´m open for international shipping.
Easiest way to contact me is by dropping me a dm on instagram: Viktorsson
https://redirect.viglink.com/?format=go&jsonp=vglnk_156788047393411&key=be5f2422f2ab66664ee34802e1b64c0f&libId=k09vju8h0100xxn6000DAirwr2eby&loc=https%3A%2F%2Fwww.celicasupra.com%2Fforums%2Fshowthread.php%3F120995-Bolt-on-custom-rear-subframe-biggest-big-brake-kit&v=1&opt=true&out=https%3A%2F%2Fphotos.app.goo.gl%2Frqo3YbrTF6EeoxFg6&ref=https%3A%2F%2Fwww.celicasupra.com%2Fforums%2Fforumdisplay.php%3F17-Parts-For-Sale&title=Bolt%20on%20custom%20rear%20subframe%20%2B%20biggest%20big%20brake%20kit&txt=https%3A%2F%2Fphotos.app.goo.gl%2Frqo3YbrTF6EeoxFg6
The problem is you are in Sweden. If you were in the USA, it would have probably sold already.
I have a picture of your car saved from a Japanese car board on Pinterest. :)
As noted, you'll probably have some difficulty selling it here, from Sweden. I can't imagine the shipping cost.
Please tell us about your car though.
From Sweden? Do you own the shipping company?
Discussion Starter #8
Yes from Sweden to a company adress in Florida by DHL, FedEx want $1600.
No I don't own the shipping company and I don't set the prices.
FedEx is smoking crack! If one wasn't in a hurry you could get a whole container to the States for $5000.
1 - 9 of 9 Posts
