1 - 6 of 6 Posts
I am having problems with lean conditions when I go into boost on my 83 5mgte that I run in my 79 toy 4x4. I have attempted to get rid of this dangerous condition by tuning the afm, and using a begi/cartech rrfpr. and even using more than enough input on both of these it still goes lean above about 3500 rpm at full throttle. I am still using the stock injectors for now and I run an aftermarket bosch fuel pump (i think). Is there any EASY way to limit boost until I can get the 295's or should I really hustle to get those injectors..
Thanks...For now I am just using a pressure switch on my cold start to dump unmetered fuel into the intake to help keep things alive and driveable
Matt
If I did my project over again and used a 5m I would probably try using a couple RC Injectors with a stand alone injector controller. It would cost a little more but I think it would work better.
You probably need to get 295. If you are running stock boost you would need to lengthen the waste gate actuating arm to reduce boost.
How much boost are you running? If running low boost, you should not be running into a lean condition, unless you've got the Cartech regular adjusted improperly.
-Aaron
I am running stock boost. With my cold start injector setup I can run to redline with it just flickering rich (at about 3/4 turn out on the needle valve). Without the cartech it can only get to ~4500 rpms before spiking lean and falling on its face. I doubt the cartech is adjusted improperly.
I am thinking it may be more along the lines of fuel pump capability, or that I have restrictions in the lines since I had to make my own pickup and feed lines out of bits and pieces of 79 pickup carburated junk. I think that if I were to run the 295's it will be better, but I am worried about off idle throttle response and loading up, since I use this truck for rockrawling and general wheeling.
Matt
Fuel pump. I think you need to get a pump that you know is bigger than a stock one. Mine acted like that before I got a higher rated pump.
1 - 6 of 6 Posts
