Brake conversion ***Now complete***
Swap #1 with wheel spoke clearance issues.
Hub:1990 to 1992 Infiniti M30 uses a floating disc and is 4x114.3. Must change studs to 12x1.5mm and center bore is 66.1mm, machine down to 60.1mm. Hub reg is 68mm. Will clear MPV disc.
Caliper:1990 to 1996 Infiniti Q45 2 piston.
Disc:1992 to 1995 4WD MPV redrilled to 4x114.3.
Napa Online
"# of Bolt Holes : 5
Bolt Circle Diameter : 4.5"
Brake Rotor Diameter : 10.86"
Brake Rotor Discard Thickness : 1.02"
Brake Rotor Thickness New : 1.1"
Brake Rotor Type : Disc Brake Rotor Only
Center Hole Diameter : 2.84"
Height : 2.52"
Maximum Lateral Runout : .004"
Vented / Solid : Vented"
Rock Auto
Swap #2
Caliper:1990 to 1996 Z32 Nissan 300ZX Turbo or 1991 to 1996 300ZX NA 4 piston.
Napa Online
Height : 2.52"
Rock Auto
Will add more later.
12-09-2003
Guys working on a front brake conversion for the MK2 that will be more affordable. Almost there. Will fit 15" and bigger wheels. There may be some limitations though.
Here is a sneak peek at it. The cardboard is temporary and is there for a reason, I'll explain later.
I should have everything worked out by the new year. Just waiting for parts, holidays to start and exams to finish.
Once completed I will post the conversion on the web so anyone can do it themselves.
Napa Online
Height : 2.52"
Rock Auto
Swap #2
Napa Online
Height : 2.52"
Rock Auto
12-09-2003
