1 - 11 of 11 Posts
hi mark,
Thanks for the bearings, I need the front and rear break pads>
are they available ?
Thank you.
Harith,
It would take me a fews days to get a hold of them, but yes I can get them. They are $39.74 per set (front/rear).
Quote# 20996
Thanks!
cool, Go ahead and order them for me, I'll send you my address to send them directly to me if its fine with you.
We'll call you to update you with the new card #.
Is it possible to get the auto transmission oil filter too ?
I also have a corolla 1979 for which i will need the same filter too.
Thank you.
Well, I can get the trans filters...but it would take me about 3 weeks to get them.
Filter - $15.43 each
Pan Gasket - $9.95 each
The two cars take the same filter and gasket actually.
cool !
then I'll need the filter and gasketfor both cars. no problem with waiting.
Thank you mark>
Banned
Really.... Sweet thatll work for meee
Ill probably go with the same on then haha, What did you do to break in your cam? I was told to hold it at about 2k for 15-20 minutes
am sorry for the delay Mark,
Was out of the contry, went to Cairo and Nairobi for work-related mission.
I'll call you early monday when you re-open. I really need these things soon !!
Thanks !!!
Hi Mark
I got to do the trans oil and filter change but the filter you sent me was not the same like that of the car :(
I cleaned the old one, changed the oil and had to delay changing of the filter till i get the correct one.
Any idea why this happened ?
Hi Mark
Harith,
The filter on both cars was updated to the number I sent you. It probably looks different, but should bolt up and work the same? That's the only explanation I have for the differences.
1 - 11 of 11 Posts
