Based on what I have seen, Toyota assembles them dry. When I assembled mine, I used a light coating of that spray tack coating. I am not sure RTV would stand up to the heat.
The heat from the exhaust is why that side leaks to begin with.
You are talking about the cam tower to head gasket?
If it is just the valve cover, you don't need to use anything. In fact retorque will usually fix a valve cover leak.
