Heres the scenario. Mk2 goes out as a friend test drives it, assuming it got driven very hard car comes back with clutch pedal to the floor.
Back at garage theres no fluid loss from the master cyl. and pedal is too the ground. We change the master thinking its a bad seal, after bleeding the system the slave is pushing out the fork fairly well. With the engine running and pedal down, you can't shift at all, but you can with engine off.
So I figure its the slave cylinder not pushing out far enough, get another one, bleed system, it pushes out about the same as last one but same problem.
Throwout bearing melted? Fork screwed up somehow that isn't pushing out the pressure plate?
