1 - 13 of 13 Posts
The clutch on my ‘85 Supra goes straight to the floor when depress so I am assuming the clutch master and or slave cylinder is bad. I am having difficulties locating these parts for my car. Does anybody have any suggestions as to where I can order a clutch master and slave cycle?
Have you looked at rockauto.com? They have like 6 different choices. Btw I'd buy the Aisin ones since they are oem.
Discussion Starter #3
Tried Rockauto and nothing comes up
Try under Celica instead of Supra, but make sure you select the 2.8L engine.
Discussion Starter #6
Thanks for the Doc- I was able to order what I need
Look under the carpet below the clutch for fluid.
Discussion Starter #9
It was the slave cylinder. Replaced it yesterday and am now back on the road. Thanks for your help.
I am having the same problem but my foot well is dry and fluid is not low? Can barely get it into first and never reverse. Any advice? Replace both?
Try bleeding it first.
And check the pushrod adjustment under the dash. Mine was waaay off, and wasn't fully releasing the clutch.
1 - 13 of 13 Posts
