I just recently put in a new clutch. Including the throw out bearing, pilot bearing, pressure plate, clutch disc, and flywheel. Since replacing those the clutch pedal goes to the floor. Sometimes it engages enough to shift other times it doesn't. When the clutch goes to the floor and doesn't engage the pedal stays on the floor. I have taken the slave cylinder off and cleaned it pretty good. And bled the system after reinstalling it. When I bled the system I opened the bleeder valve and dumped fluid in the reservoir until it ran out on the ground. then I closed the valve and topped off the reservoir. Pumping the pedal after that there was little to know change. Any thoughts?
