1 - 5 of 5 Posts
ok so i have a 7mgte and everyone says to use the 5m flywheel and clutch and what not. my idea was buy a nice 7mgte pressure plate and like a 5m clutch disk. how im taking this as is that the w58 and r154 clutch disks are different, so do they have like a different pattern like more splines on the output shaft or what is the real difference and will this work??? didnt really know what to search for so i decided to just post.
Will
Diff diam and thickness of said disc
7mgte
Clutch Specs:
Kit #: 16-063
Disc Diameter (in): 9 7/16
Spline Diameter (in): 1 3/16
No. of Teeth: 21
93 up trannys
Kit #: 16-093
Disc Diameter (in): 9 7/8
Spline Diameter (in): 1 1/4
No. of Teeth: 14
5mge
Clutch Specs:
Kit #: 16-018
Disc Diameter (in): 9 1/4
No. of Teeth: 21
R154 and W-58 are different style(push vs pull) trans, so your idea wont work-7mgte flywheel and press plate wont work with w58. Do some more reading. This has been covered bout a zillion times.
1 - 5 of 5 Posts
