1 - 11 of 11 Posts
In order to keep things semi-clean here in regards to number of stickies. I though I'd post up links to some of the restoration topics/thread that are in the FAQ area to serve as sort of an index. If somebody has another link post it up and I'll add it. Or has a recommendation on another thread LMK. Consider this a post in progress.
Saggy Door Map Pocket Fix
Drivers Seat Lumbar Bulb Replacement
Cruise Control Light Bulb Source
Sagging seat back nets
Window switch plate fix
Fixing chrome seat back trim
On The billboard version, the keyhole of the lock is perfectly in the way of the P. For best results, remove the keylock, install the decal, cut the P in order to install back the keylock.
wait is that sunshade magentic? great idea there
YEP!
Made it from 2 sunshades,magnets glued to the glass under,some washers on top.
I am the magnet man.Hard drive magnets work fine.Keeps the inside cooler in summer.
Sometimes,it blinds tail gaters if the sun is just right.
Disable the rear wiper,in case you hit the switch! I jacked mine up with a wire slid into the wiper arm hole.
1 - 11 of 11 Posts
