I just wrote this up again at Supraforums and I though some of you might want the info, so here it is:
If you're converting kg/cm^2 (on the GReddy gauges and other brands as well) here are the factors so that you can do it by sight (from http://xtronics.com/reference/convert.htm):
1.0 kg/cm^2 = 14.223 psi
1.0 psi = 0.070309 kg/cm^2
1.0 bar = 14.508 psi (this means that 1.0 bar != 1.0 kg/cm^2, but is close)
0.8 kg/cm^2 = ~11psi = stock boost on a JZA80
~1.15 kg/cm^2 = 16psi (max boost without detonating on 92 octane on JZA80)
~1.25 kg/cm^2 = 18psi (typical boost people run on 100 octane on JZA80)
