1 - 6 of 6 Posts
mine came loose and fell out. i'm gunna try looking in the wrecking yards today. would a crank pulley bolt from any of the M series engines work? (4m,5m,7m)
$12 from Toyota dealership. It is absolutely BEST to just get a new one as the threads stretch over time.
+1.
Also only a 5M pully bolt will work, a 6/7M pulley bolt will be too large in diameter.
Discussion Starter #4
i called my local toyota dealer and they told me they could not get it in. i found one from a 86 5m, put some lock tight on, and hopefully it will hold. i'll be checking it regularly untill i can replace it with a new one.
Torque spec is pretty high, lock tight probably not needed.
Mark should be able to get you the bolt.
+3
I've gotten this exact bolt from Mark in the past year (see the Vancouver Toyota (WA, not BC) forum - and see the sticky on how to contact him on parts).
If you have an A/T, good luck with ever getting to the torque spec on the bolt with the engine in place.
1 - 6 of 6 Posts
