2 Toyota techs told me that the little hose from the top of the cam cover to the intake throttle body is not enought to vent the internal pressures, specially if i want to go turbo. (5mge)
Also, I replaced the front seals and I am still leaking very badly from the front pully. So,
I cut the hose from the block to the cam box, the one next to the distributor and put a T and ran a second hose to a breather. I put the breather up high so oil would drain back to the crank ( I ran the hose and breather over to the top area of the clutch resevoir.
Well, this set up just blows a ton of oil out, and puffs like a smokestack.
Is this normal?? My plan was to go to a oil catch can, but I dont think it can handle all this blowby? I have new rings but have not checked compression lately.
