1 - 9 of 9 Posts
So what kind of boost levels are all you turbo guys running? What is the stock boost level that the wastegate actuator is set at? I hope its less than 7-8psi cause I don't want to be running a lot. If it is higher what do you do to lower it?
This is all good news. Thansk guys! I was worried Id have to Modify the wastegate a bit.... Im also surprised, I would have thought that the stock 7M's woudl be running a bit more than 6-7psi :?
I believe that a stock 7mgte with the ct26 runs 5.5psi.
1 - 9 of 9 Posts
