1 - 20 of 36 Posts
Just had the car inspected to only have it overheat once again. I'm starting to think this car is cursed.
I replaced the water pump, fan clutch, and radiator. Drove it all this week with no issues besides the bad brakes. Then just like that the car is back to square one. Not only does my car not have a working headlight but it now has shocks that are useless. I can literally move the car up and down with my pinky finger. After inspection I also found out that my car has been rolled back!! I suspected this since the 2 and 3 on the 100k mark are half way in between. Someone help me! Ive ran out of ideas!
Previous posts about this money pit:
· Administrator
Will it is at least a 30 year old car with one of the least reliable Toyota engines ever that most have been beat on to death. What did you expect?
There may be something in common with all these issues: wiring and grounds. When I had one headlight fail, it was something in wiring very close to that particular headlight. Issues near headlight switch would cause both of them to fail.
Anyone know where to even start with the overheating?
Have you:
  • determined if you are or are not losing water from system?
  • verified actual temp of radiator and that it matches gauge?
  • tested thermostat in pot of boiling water?
  • pressure-tested radiator cap?
  • back-flushed radiator? Clear fins of bugs and grime?
Have you:
Yes the car was losing quite a bit of coolant so I replaced 90% of the hoses in the car and the ones that are left are easy to reach and see
No I will when it stops snowing
Yes it failed so I bought a new one
Yes also failed
Yes
I replaced my radiator for a new mishimoto and it still overheats so I have no clue
Is the coolant boiling out and getting replaced by gas in the system even under normal driving? Because if so you probably have a BHG.
From what I’ve read on the forums in order to have a bhg you need to have bubbling in the overflow, smoke, overheating, etc the only symptom my car has is overheating
If it is overheating for no reason and slowly pushing coolant out which is replaced by gas, you have a BHG. Especially on a 7M this is a huge red flag. Use a block test kit if you aren't sure.
Reactions: Fritz and Tanya
Ill grab one tomorrow
depending upon how headgasket is damaged, it may lose coolant without blowing too much back into coolant jacket. I've had some that was such small leak, car went on for months with only needing bi-weekly coolant top-off.
Then there's this BHG from being greedy with too much boost. I dumped entire coolant system out tailpipe in giant white cloud down Willow Springs front straight! Ended up replacing headgasket overnight in parking lot so I can get back to racing on Sunday. :)
I take it there's no external coolant leak that's causing puddles under car?
Nope none, a little oil leak from the diff and thats about it
It's been said hundreds of times - swap the engine. Anything is going to be more reliable than that 7M BHG-prone boat anchor. I put a NA 2JZ in my MkIII DD 5 years back and it's been reliable, smooth, and economical ever since. The swap has been dozens probably thousands of times, so it's well documented. Even an NA will net you 20 additional horses and 20 more ft-lbs of torque.
I have had an 86 1/2 with a 7MGE and an 89 with a 7MGTE with assorted cooling issues. Check for leaks from the heater hose (formed, sometimes they fail in the inner curve of the hose), and the heater union (top back of engine, can weep but not show evidence b/c antifreeze evaporates on the transmission before it hits the ground). Also, replace your thermostat with OEM, as it has a UHC larger opening than aftermarket (I looked). When adding antifreeze, be sure to burp the system (read: no air).
Drove the 7MGE with no evidence of a BHG (except threat of overheating) for years; not a great idea, but she was good to me.
1 - 20 of 36 Posts
