1 - 6 of 6 Posts
Hi guys im new to this forum ive have not long bought my frist celica supra I ended up with three to make one good one. That I resceuced from a farm. but anyway the one i'm building up is in pretty good shap but need a few rust repairs done and some are pretty major., Im from New Zealand so its running a 1ge-gu 2l six twincam 5speed not 2.8 dohc goes realy well for what it is but hoping to put a 2jz-gte in when get the money at the moment just restoring it to get it back on the road im having a little trouble with one of my doner cars trying to get the dash bord as in the whole lot ive pull out all the bolts i can see from the front as well as glove box and gauges out but just still does Not want to move are there any hidden bolts screws that i should know about?. :32: thanks
When you are talking about the front, did you pop out the defroster vents and take out the 4 screws that are underneath them?
hmm
No i dont think i have thanks., so do you just use flathead screw driver to pop them out or do they have little clip on them?
Flatblade screwdriver works just fine. There are metal compression clips that holt them in, but it is not hard to pop the vents off.
Careful not to break the fins on the vents, the plastic gets pretty brittle... good luck with the project!
I used a wide putty knife to pop them out as I didn't want to bend up the vents to see the clip location.
Be careful and good luck!
1 - 6 of 6 Posts
