Here is just a partial list of the parts and tools stolen from my facility early in Aug.
I urge you to be on the lookout for these parts. Someone is going to brag about this to someone at a party, or offer to sell you something that is not theirs to sell. Please pass any possible leads to Detective Sgt Matthew Jeary of the Waterloo Regional Police Service at at 519-589-6711 or anonymously to Waterloo Police Crimestoppers at 1-800-222-TIPS or online at http://www.waterloocrimestoppers.ca/...page=submittip. You can also text message your tip in. Send your message to “CRIMES” (274637), and put “TIP152” at the beginning of the body of the message. Your messages are secure and anonymous.
MKIV SUPRA PARTS - NEW IN THE BOX
1 kit TRD Replica WideBody Kit for 1993-98 Supra
1 pc TRD FG Replica Wing,
1 pc Seibon Carbon Fiber Hood for 1993-98 Style, TRD Style
1 pc MVP Motorsports Turbo Blanket, Black
1 pc TRD Oil Cap for 1993-98 Supra
1 pc Mishimoto Silicone Hose Kit for 93-98 Toyota Supra Turbo, Blue MMHOSE-SUP-93BL
1 pc Fluidyne Radiator for 1993-98 Supra FHP11-93SUPRA
2 pc Power Division (GSC) Stage 2 Camshafts for 1993-98 Supra TT 6030S2
1 pc Tein EDFC Controller Unit EDK04-K4469
1 pc Tein EDFC Motor Kit EDK05-12120
1 pc Powerhouse Racing Street/Race Intake Manifold
1 pc Powerhouse Racing Modified Oil Pump for 1993-98 Supra
1 pc Powerhouse Racing Breather Kit for LHD 1993-98 Supra, Red & Blue Fittings
2 pc Powerhouse Racing Stainless Steel Clutch Line for 1993-98 Supra M/T
1 pc Powerhouse Racing Upper Rad Pipe for 1993-98 Supra, Polished Stainless
1 pc Powerhouse Racing Timing Belt Tensioner Bracket for 1993-98 Supra
1 pc MVP Motorsports Upper Shock Arm for 1993-98 Supra 6-speed T-4002
1 pc MVP Clutch Master Cylinder Reservoir Cover, Polished T-4036
1 pc MVP Motorsports Aluminum Igniter Cover for 1993-98 Supra T-4035
1 pc TTC Brake / Power Steering Cap, Polished T-4032
1 pc TTC Performance Water Pump Pulley Cover, Aluminum Finish T-4000-TC
1 pc TTC Supra Script Windshield Washer Fluid Reservoir Cover, Polished T-4033-TC
1 pc TTC Performance ABS Cover for 1993-98 Supra T-8120-TC
1 pc TRD Oil Cap for 1993-98 Supra 12180-SP020
1 pc TRD 160 Degree Thermostat for 1993-98 Supra 16340-SP020
1 pc Unorthodox Racing Idler Pulley for 1993-98 Supra 11270712
1 pc Unorthodox Racing Alternator Pulley for 1993-98 Supra, Silver 11230712
1 pc Unorthodox Racing Power Steering Pulley for 1993-98 Supra, Silver 11240712
1 pc Unorthodox Racing Water Pump Pulley for 1993-98 Supra, Silver 11250712
2 pc 2 AP Engineering Shifter Bushing Kit for 1993-98 Supra 6-speed & 5-speed
1 pc HKS Titanium Exhaust for 1993-98 Supra Twin Turbo 3108-RT001
2 pc HKS Version 3 Universal Blow Off Valve Kit 71007-AK001
2 pc HKS SSBOV Flange, Aluminum 1410-SA003
1 pc Max Air Airbox with no pre-cut hole
1 pc RPS Carbon/Carbon Twin Disc Clutch for 1993-98 Supra TT BC2PK-22170-AL
2 pc StopTech 14" Big Brake Kit for 1993-98 Supra TT, 4-Piston Black Calipers, Slotted Rotors, Front 83.857.4700.51
2 pc StopTech 14" Big Brake Kit for 1993-98 Supra TT, 4-Piston Black Calipers, Slotted Rotors, Rear 83.857.0047.51
1 pc Apex Overflow Tank 573-A001
1 pc Greddy Oil Cooler for 1993-98 Supra, 16 Row, Includes Remote Filter 12014405
1 pc Titek Carbon Fiber Radiator Cooling Plate for 1993-98 Supra - Dry CFP-84001D
2 pc Titek Magnetic Drain Plug for Toyota and Nissan, M12xP1.25 MAGDP-RD
1 pc AEM 6-in-1 UEGO Gauge 30-4100
1 pc AEM Water/Meth Injection Kit 30-3000
1 pc AEM Inline Water Injection Filter 30-3003
1 set ARP Main Stud Kit for 1993-98 Supra TT 203-5405
1 set ARP Rod Bolts for 1993-98 Supra 203-6005
1 set ACL Race Series Rod Bearing Set for 1993-98 Supra TT - Standard 6B8100H-STD
1 set ACL Race Series Main Bearing Set for 1993-98 Supra TT - Standard 7M8103H-STD
1 set ACL Race Series / X Series Thrust Washer Set for 1993-98 Supra TT - Standard 2T8103-STD
2 set R2 Racing Steering Rack Bushing Kit for 1993-98 Supra 800-ST100
1 pc "Secret Carbon" Carbon Fiber Airbag Gauge Pod, LHD
1 pc MVP Triple A-Pillar Mount for 1993-98 Supra, 60mm
MISCELLANEOUS UNIVERSAL, MKII, MKIII/MKIV PARTS, NEW or USED
MKII
4 set Addco sway bars 745/375 sets
1 pc Cusco MKII front strut brace blue
2 set Ground Control 8010.01 MKII coilover kits
MKIV
1 pc Toyota 2JZGTE engine w/T78 turbo, braided fuel line, billet fuel rail, 720cc injectors, FPR
1 pc Toyota V160 transmission Getrag 6 speed
1 pc RPS sport clutch w/6 puck disc, new
1 pc RPS Syn-R-G flywheel segmented surface, newly rebuilt, like new
1 pc TIEN HA coilover green, near new, one unit missing spring perches
1 pc TRD MKIV front strut brace
2 pc Cusco MKIV front strut brace blue, one with Japanese price sticker
1 pc Toyota MKIV wing green
1 pc Toyota MKIV wing red
UNIV
2 pc Sparco Milano race seat grey Alcantra suede, mint cond
4 pc Enkei wheel 18x8, 18x9 5 thin spoke silver rims w/tires, brush painted black behind spokes, Supra decal on spoke
4 pc BSA 215 wheel 18x8 (2) 18x9 (2) black 10 spoke center, polished lip w/new Falken tires
4 pc BSA 215 wheel 18x8 (2) (unmounted, in boxes) 18x10 (2) black 10 spoke center, polished lip w/new BFG KDW tires
1 pc APEX-i S-AFC ECU fuel computer
1 pc APEX-i AVC-R ECU turbo boost controller
1 pc Blitz Dual-SBC Spec-R ECU turbo boost controller
1 pc Defi Control Unit II - Version 2 DF05002
1 pc Defi BF ** US SPEC ** Boost Gauge, 60mm, White DF04303
1 pc Defi BF **US Spec** Oil Pressure Gauge, 60mm, White Imperial DF04403
1 pc Defi BF **US Spec** Oil Temperature Gauge, 60mm, White Imperial DF04603
1 pc Defi BF **US Spec** Water Temperature Gauge, 60mm - White Imperial DF04703
1 pc Defi BF **US Spec** Fuel Pressure Gauge, 60mm, White Imperial DF04503
1 pc Defi BF ** US SPEC ** EGT Gauge, 60mm, White DF04803
1 set 4300K Xtreme HID Conversion Kit for 1993-98 Supra - high beam XT-AK-9005
1 set 4300K Xtreme HID Conversion Kit for 1993-98 Supra - low beam XT-AK-9006
1 pc Setrab oil cooler silver 4x4x30", blue -10AN caps
50 pc Samco silicone IC couplers, various sizes, new, no pkge
1 set Addco sway bars 385/776 set
4 set 8mm, 10mm, 15mm alum wheel spacer sets, with Japanese price tags
TOOLS
2 Mastercraft tool cabinet 2 units, 5'H, all tools
1 Rigid shop vac 24"dia w/access
1 Mastercraft battery charger 24" H, floor model w/wheels, 6 settings, black
8 sets Mastercraft sockets 3/8" & 1/2" drive Metric deep chrome and impact sockets
4 sets Mastercraft wrenches Gearwrench Metric open end ratcheting wrenches
Central Hydraulics 20 ton floor hydraulic press, orange
1 Powerfist floor jack 2.5 TON, orange
4 Powerfist axle stands yellow 2 ton capacity
1 Powerfist engine stand yellow 1250lb
Wen polisher blue
Craftsman angle buffer,black, missing side handle
Hand tools in cabinet consist of STC torque wrenches, valve seal service tools, multimeters, hammers, screwdrivers, Allen key sets, sockets, COP coil pack tester, torque angle gauge, compression tester, thread chaser set
There is much much more as it was difficult to determine from the debris whether or not something was stolen or incinerated - it's likely someone either has set up a small shop somewhere with the tools or will sell them individually to avoid suspicion. Please keep your ears/eyes out for anything that appears fishy.
MKII
MKIV
UNIV
TOOLS
Wen polisher blue
