So if you have to seperate the two halves to add your replacement why not use the outer piece from a spare 5M pulley to fix it. I would be intrigued in how you could seperate the two halves and reattach them, maybe I'm misunderstanding something here. The only difference between the 5 and 6M pulley is the inside part, which is probably the same as a 7M one.
