1 - 11 of 11 Posts
Figured this would help out everyone thinking about rebuilding their rear differentials...all the pieces needed to overhaul a F-code MkII differential. Add or subtract as you feel necessary as it pertains to your car's needs. Just add the recently released LSD rebuild kit and you're drifting again!
41301A - 90368-45002 – Side carrier bearings $39.61 ea (x2)
41201A - 90366-35023-77 – Inner Pinion Bearing $55.20
41201B – 90366-30022-77 – Outer Pinion Bearing $36.54
41334B – 90311-38011 – Axle Seals $9.30 ea (x2)
41201C – 90311-38010 – Pinion Seal $12.28
41231 – 41231-22010 – Pinion Crush Sleeve $9.88
41182 – 41182-22011 – Cover Gasket $6.67
41108B – 12157-10010 – Oil Plug Gaskets $.79 ea (x2)
41204B – 90179-18001 – Pinion Nut $4.00
Total... $223.97
(Pricing subject to change without notice, last updated 03.27.09)
crashtest dummy
Mark - I am about to redo a rear and have a box full of new parts that I bought years ago - just trying to sort through what is what to see what else I need. It seems that many of my part #'s are off from what you have listed; I was just wondering if its possible that some of these would be superseded #'s?
90368-34083-77 (bearing)
90366-30001 (bearing)
90179-20061 (nut)
90311-38047 (seal)
90311-48122 (seal)
90311-38009 (seal)
42413-22010 (spacer)
Thanx for any help.
Hey Mark.....
need one. Shoot me a PM with the total and if possible bring it up with the other stuff on saturday.
Discussion Starter #6
90179-20061 (nut)
90311-38047 (seal)
90311-48122 (seal)
90311-38009 (seal)
Thanx for any help.
The numbers you have listed are rear wheel bearing numbers, not rear differential bearings :duh:
mark this might hurt to hear but, can you get any finial drive set's. and what ratio and price do they run??
oh and i think this would be a cool toolbox sticker.. 41991 :D
What would make a cool sticker? :ugh:
James...R&P have been available in the past for any of the normally mentioned gear ratios. Here's the main ones...
3.58 - 41201-39795 $557.36
3.73 - 41201-80107 $588.87
3.90 - 41201-29517 $615.52
4.10 - 41201-80110 $588.87
4.30 - 41201-80004 $588.87
3.07s are no longer available new...you'll need to find a mid eighties pick up truck with a 4 speed to get those
Hey Mark.....
No...I was told not to feed your addiction for Toyota parts ;)
I'll have it with me on Saturday Robert...$7.25 should cover it!
Right on, thanks for the diagram!
You are most welcome sir!
So looking for these parts with these numbers is just not working out for me... Must be doing something wrong idk... any help would be awesome cause i have a diff that needs some serious love...
These are Toyota part numbers, not autozone/napa/oreillys/advanced/etc.. numbers. Should be able to look up all parts via 1985 Toyota Supra. If your installing a Truetrac LSD, you will need the carrier bearings for a 89 4Runner 7.5in front differential, not the 85 Supra carrier bearings.
http://www.celicasupra.com/forums/showthread.php?10188-true-trac-writeup
William 2 Thumbs Up for the write up!!
1 - 11 of 11 Posts
