1 - 13 of 13 Posts
Constructed of 3/4" EMT(Electrical Metallic Tubing).. Bought a 10 foot section, I could make multiple bars with.. Mine is actually bolted to the seat latches, as my sub box was in the way ot the two strut towers, i've been told it's just as strong...
-Andrew
Just hammer the crap out of the ends, so it's reasonably flat, then drill a hole, heres my cheezy paint interpretation of what I did..
If you plan on attaching it the same way, make sure to offset the hole to fit the seat brackets, they should be slightly towards the front of the car. You'll see..
The finish is a roll bar spray paint...
-Andrew
Administrator
Here's mine;
http://www.pbase.com/image/15099140/large
Still a WIP. It needs a lot more polishing, still a little hazy (no as bad as the photo looks though). Its just 1 x 2 x .125 wall 6061 tubing with the proper holes milled through to drop a M6x20mm SHCS though.
Sweet looking bar!
will
Hi guys. I'm working on a rear bar as well. I decided to go with a bar that is one piece, and does bolt up to the seat latch area, with plates skinny enough so you can retain use of the latch mechanism. I've currently got an order for the mounting plates to be laser cut, and will be selling these shortly. I didn't know there was any interested for bolting these to the seat latch area, until I read this post today, August 9th. I'll learn to pay attention one day! Catch you later folks.
-Aaron
Shoot us some pics and prices when you get em!!!
I'm also working on a bar for the back. I bought a bar from ebay for about 20 bucks. They have a large number of bars from 12.99 on up. You just need the right size bar, about 43 inches. My mechanic and are are working on a weld in or bolt in solution for mounting. I'll take as many pictures as I can and keep everyone informed.
1 - 13 of 13 Posts
