1 - 5 of 5 Posts
I been having a problem with my driver side door light coming on/off whenever i go over big or small bumps or if i do sharp turns.
Somtimes having trouble closing the door shut.
It is very annoying since the sounds and lights come on!
What could be the problem?
thanks,!
Supremefreak, do you run a MkII?
If so, cool running!! :woot:
Are there many :mymk22: left in Japan?
I know most "old school" cars there end up gomi all too soon...
thanks,!
Adjust the striker for sure, but also check to see if the hinges are worn - with the door partially open, about 20cm, lift up on the back end of the door and see how much play there is in the hinges. Might need replacement. I have good used ones here if needed.
BOb
1 - 5 of 5 Posts
