481 - 500 of 526 Posts
On my old drivers side mirror,I stuffed some closed cell foam in there to remove the vibrating WOBBLE.It was terrible!
The one that I have now is OK.
Discussion Starter #482
Thanks for the tip on wedging some foam in there.
Now if I could get the glass to pivot a bit further on the little motorized mechanism I'd be happy!
Discussion Starter #483
Moving Along.....
Here's some pix of what I've been up to lately.
Got the wiper arms cleaned and painted. Anybody who's seen the car in person knows they were bright red with rust. They cleaned up great with some little Scotch-Brite buffs in my Dremel, and it's just the rattle-can Krylon that Dave recommended.
The cam covers need another coat of color on the letters. I baked them in the sun for several hours, and the red and yellow shrunk down enough that I can see some shadows in the paint, so I'll give them another color coat on the lettering.
And I scrubbed "Timing Cover #3" in the sink to get it nice and clean. Then I noticed some nasty molding flash that had to go, so I spent some time cleaning that off and blending it all in. Then I noticed since it was so clean, that the plastic is glossy, BAD for paint adhesion, so I scuff sanded it. Then I noticed it had some nasty low spots, so I wound up block sanding it. Just waiting for Saturday when It'll be 85*, and perfect for wrinkle painting. I'll scuff off any remaining gloss with a Scotch-Brite pad.
At this point I'm going to declare Summer is over, and get to work on all the delayed maintenance that it needs done. I'll back it out and drain the coolant, then pull her back in and start pulling the radiator and all the stuff on the intake side. That will let me change the timing belt and tensioner easily, along with the starter, fuel filter, and fuel injectors. I can cleanmost of the crud off the parts out in the garage before it get too cold, and then detail clean and check them down in the nice warm basement this winter.
And having all that stuff out of the way should make it easier to get dimensions and figure out what I want to do for an electric fan. Moving to 5000' elevation makes me want to get rid of parasitic losses like the engine-driven cooling fan so I can regain a bit of what I lost with the decreased air density her.
- Jim
Jim,that Krylon rattle can is BEST that I have ever used~!~~
My entire hood was painted with that!
When I pull off that lower cowling,below the wipers,that go on it.
All 3 wiper arms have it.
NO ISSUES!
That paint went on my battery hold down,last week.
I used plastic paint=gloss black on my timing cover AND my radiator shroud.
Shiny black.
I cleaned and painted my lower plastic engine cover with WHITE plastic paint.Just the upper side.
Easier to find lost bolts!
Yes,I still use one.
I didn't go with electric cooling fans because my alternator is still the stock one.
I went with LED tail and brake and turn signal lights.
The most difficult part was changing out the turn signal flasher!Mod was done by Ray for me.
My LED fogs have not gone in,yet.
These are the same ones that Greg('82 Supra) likes.
https://www.ebay.com/itm/CREE-LED-50W-H3-White-5000K-Two-Bulbs-Fog-Light-Quality-Replacement-Fit-JDM-Lamp/162075725041?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I ALWAYS use my fogs during the day time,but I can see the voltage drop with the Halogens.,.
Discussion Starter #485
I'll swap out the alternator when I have the front of the engine and the radiator out. Gives me a little more room in there to maneuver!
Discussion Starter #487
There's a lower radiator/fan shroud? I thought it was one-piece.
I'll have to look closer. Probably not a big deal (yeah, right....) as I'm planning on pulling it all anyway.....
The lower part of the one piece radiator shroud encompassed the lower radiator hose. You will see.
Break it!
You may choose to shoot the radiator shroud with black plastic paint.
I like the look.
[url=https://imgur.com/56wWIXR][/URL]
I also BROKE the lower shroud on PURPOSE to make it easier to remove.,past the lower hose.
I had a few questions about your engine bay. Is that a laptop fan next to your coil that you use to cool your coil down? Would you recommend someone to install it or did you just put it there for peace of mind? Also, what is all the insulation for?
I was having a hot soak issue and the ignition coil gets REALLY hot. The hot soak issue was not caused my the coil overheating.
Then, I covered up the the AFM for the same reason and that helped a little.The AFM has a temp sensor that changes the air-fuel ratio. If it senses a high temperature,it leans out the mixture as the ECU sees it.
I did the shiny stuff over my aluminum Chimpy intake tube because it sits right above the exhaust manifold.
Cool air is GOOD air.
The under hood temps are quite high.The coil was temped @ 160*.The battery was @ 130*.
I thought that the firewall was picking up heat from the engine and baking me inside of the cabin.
The cabin heat is mostly transferred from my tranny,not the under hood heat.
My transmission tunnel was not treated with insulation,as it should have been.
The A/C was yanked out,years ago.
Break it!
On the very early C3 Corvettes, one had to remove the right front upper A-arm to be able to get the fan shroud out because it was already on the body when the body was dropped onto the frame, thus being sandwiched in. It became popular to cut the shroud through the bottom to be able to collapse it, then stitch it back together upon reinstall with a piece of sheet metal and small bolts or screws. Today, restorers will pay $300-$400 for an uncut original fan shroud. Just food for thought......
Discussion Starter #492
Interesting about the C3, Phil. I never had the shroud out of my '69 T-Top, but I do remember how packed in it was from the times I had the engine out.
Not gonna cut the one on my MKII, I'll just work around it.
I wish I would of taken pics when crewing on the '69 C3 back in the day...I've forgotten 90% of what I used to work on the car...
Discussion Starter #494
Mine started as my daily driver, then wound being an SCCA B-Production car for a while, then a buddy bought it, and put it back on the street (I kept everything I took off it) and autocrossed it.
This car was a B-Production car at Laguna Seca and Sears Point, other tracks in the PACNW 74-77...then went SP/Trans-AM from 78-80 w a 454...my best friend was crew chief and actually got his SCCA in the car at Sears Point in 77/78. I worked on it from 77-80 then the car was sold....
Discussion Starter #496
I ran in the Chicago region, but never did very well in the Corvette. I did much better in B-Sedan with my Firebird.
Discussion Starter #497
New Mirrors!
Thanks to eightsxxmkii, I now have brand spankin' new set of mirrors for Ms Swan.
New as in still in the plastic bags inside the box, with all the hardware and instructions.
THANK YOU!!
I don't know wheter to put them on now, or wait until Spring!
You must be a very happy camper! I like them. A LOT. Bigger and they hang out farther.
You can wait until spring,but I couldn't stand it.
NEW parts for my car?
Pretty soon,your fingers will be to cold to function. Can you even wait,Jim?
March,2020?
Oh,we will be here.
Discussion Starter #499
They're so nice I'm afraid they'll get bashed over the winter moving stuff around!
I'll put the passenger one on tomorrow afternoon and take some pix.
I'm headed out at O-Dark-Thirty tomorrow to see the Union Pacific 4014 Big Boy steam engine go by. A buddy of mine is a huge UP Steam fan, and he knows where to go to get up close and personal at the sidings it goes past.
The Tom's mirrors are *maybe* 1/8th inch taller, but they're over an inch wider, and they look like they stick out further, so they should give me a better field-of-view than the stock mirrors.
THANK YOU!!
nice score bud!
