1 - 7 of 7 Posts
aka Mr Whisker
A project I had started on awhile back and never got around to...dry carbon fiber spark plug galley cover.
FYI, dry carbon fiber is different than wet carbon fiber in that much of the epoxy has been evacuated under vacuum. Minus the epoxy, it's lighter, stronger and not as prone to heat.
Anyway, I cut the cf to shape, pressure fit into the galley with edge guard...
Motor vehicle Hood Automotive design Vehicle Automotive exterior
The spark plug wires loop out of a hole lined with aircraft edging.
Motor vehicle Automotive design Automotive exterior Audio equipment Hood
Wedged just under the Chimpy and brake booster line
Vehicle Motor vehicle Automotive design Automotive fuel system Automotive exterior
it does not go back far enough to impede the throttle linkages
Motor vehicle Wood Gas Automotive tire Automotive exterior
Motor vehicle Car Vehicle Automotive air manifold Automotive design
The old 5mge just got a makeover... (y)
Vertebrate Cartoon Plant Mammal Organism
want!
Reactions: '82supra and AJ
aka Mr Whisker
Not sure how it will hold up directly on the engine over the long haul. It's made the same as my cooling panel which has held up for years now. Here's some shots in the daylight...
Before:
Motor vehicle Automotive design Automotive air manifold Automotive fuel system Auto part
After
Motor vehicle Hood Automotive design Automotive air manifold Automotive exterior
Reading the header I was thinking ‘I don’t think it’s gna look good’
but you know what…I dig it. I used to have access to pre-preg and vacuum bagging/kiln facilities at work, but no longer, but I do have edge guard (perks of working in the aviation industry). I do have a sheet of 2024, could whip up a brush look plate.
1 - 7 of 7 Posts
