1 - 5 of 5 Posts
I got a Supra 5M-GE M/T ECU 22 pins (9 & 13, part# 89561-14130). Is this the early fuel injection one?
If it's the early ECU, can I simply attach it to a 5M-GE that used the newer fuel injection ECU? If not, what's different?
Is there a diagram of the ECU pinouts for this ECU on the web somewhere?
TIA
· Premium Member
What you have is a 8108-8208 ECU very early MA61 with EFI (no TCCS). The later ECUs are for TCCS more than likely will not interchange.
TIA
Correct! The 83 and up ECU's are microprocessor controlled (hence the name TCCS for "Toyota Computer Control System") The 82 ECU has the capability of controlling only the fuel injector operation based on sensory inputs. The 82 ECU can't operate or control an ISC valve or electronic ignition timing like the later model ECU's.
1 - 5 of 5 Posts
