1 - 3 of 3 Posts
soo... last weekend i pulled a supra from a bush and snow bank and was working on it today and got it running after alot of research from a 82 starting and electrical diagram thing is i had to jump a wire from the efi relay plug to the negative on the battery so there is a poor connection somewhere does any one have a schematic for a 1983? or opinions..
ill try to explain what i done the best i can the efi main relay has 4 wires 2 wires just run through it for a resistor the other 2 are magnetic switch on wire is positive from ignition and when power is on sends power to the coil... well i got power coming from the ignition its the wire somewhere between it and the coil goddamed if i know this is what the schematic says im lost some one help i dont wanna run jumper wires
Discussion Starter · #2 ·
the coils are different from 82 to 83 a 1983 schematic would be really helpful
1 - 3 of 3 Posts
