egr valve ... better to block it off??
4679 Views 24 Replies 15 Participants Last post by  glntom
I was going through ebay and came accross this add...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2445555909&category=33607
is it better to block off this valve when installing turbo or not?
is it good to do this on a regular 5mge engine anyhow?? :roll:
1 - 20 of 25 Posts
EGR is not good for your engine. It gums up the intake and causes the #6 cylinder to run hotter. It also drags down the cooling system by having to cool the hot exhaust gasses headed for #6. Block plates are good but blocking off the cooler is even better (like JDM engines). Suprasport sells block plates too for the 7mg. I'd like to see someone offer the EGR cooler plug too.
Very interesting Wade.
If the JDM's have'm maybe someone should send the required parts out of one to Aaron or Jim or .....for duplication.
No more emissions for me so I'm game.
DJ
EGR's SUCK.
Screw Emissions :roll:
George
1984 Supra 6m - No EGR
1989 Supra Turbo - JDM 7mgte - No EGR - Canadian Tire Didn't even notice during my emissions test...I love those morons...so japanese ignorant :D
The engines are designed with the EGR, it actually lowers combustion temps. If you just disconect it without changing fuel mixture you can burn the valves. It gains you nothing in performance, you only pollute the air more.
Take a look at:http://www.autoshop101.com/
I'm in Canada dudes.
BRING ON GLOBAL WARMING !!!!
DJ
Autoshop101.com isn't going to tell you to violate federal law sloop. And while the EGR won't significantly reduce power output when it works right, it raises heck with our engines in the long term. Carbon deposits in the intake and combustion chambers are greatly increased over time when the EGR is in place and functioning properly. As oil consumption increases due to age and miles the situation is aggravated.
As for changing the mixtures,... The ECU does that constantly about 10 times per second. Don't worry about it.
Nox emissions are reduced with its use. It does this by reducing cylinder pressure under part throttle load,...
And since cylinder pressure is what drives the crank, it will affect part throttle power.
Think what you want. Do as you please, but it IS against the law ;) .
Jamie
When I pulled the cylinder head off my 105K engine, it was clean as can be. With a functioning EGR.
Disconecting the EGR for more power/less carbon is an urban legend.
when I pulled the head off my 100,000 km 5m, it was super carbonated in the intake ports, combustion chamber and exhaust (of course).
Both JDM engines I've bought had clean intakes while all the US EGR engines I've had apart were caked with carbon. The EGR raises intake temperatures which costs HP. The EGR gasses are also unusable, containg no conbustibles or o2.
Yes, we can differ. Do as you like with your own car. I do think there are two schools of thought on the EGR. I strongly doubt that performance will be improved by it's removal. That's what my research tells me, you are definitely entitled to your own opinions on the matter.
Another article:
"What it does:
It reroutes burnt exhaust gases back to the intake air. The effect of the introduction of inert or incombustible gas increases gas mileage by displacing burnable oxygen/fuel withought effecting the air/fuel ratio. It decreases cylinder temperature (less boom, less heat), increases gas mileage (less oxygen, less fuel needed), and reduces the amount of NOx getting into the atmosphere."
If you are looking for performance upgrades, removal of the EGR has to be one of the least effective for time spent.
I have always thought piping exhaust gases back to the intake to be a strange thing.... sorta like running a garden hose from your ass to ...
well , you get the idea.. the JDM engines that i get from japan dont do it! They come with nice caps on them.
this is exactly the point, i dont belive there to be any gains in performance
but it helps in many other areas to have it blocked off
here is a post from sf on a good way to block it off on the cheap
http://www.supraforums.com/forum/showthread.php?s=&threadid=147181
hth
Scott A
82 Ptype
You just said it all right there-less fuel/air-better milage.
More fuel-more air = more horsepower,however minimal it may be.But,if it's enough to affect milage,it's probably a noticable difference in HP.
to me this doesn't make sense...if you displace normal air with "inert gases" then u would HAVE to affect the a/f ratio, maybe the ecu won't know this but u will have to because there is less air and the same amount of fuel...
doesn't affect it a whole lot, i wouldn't assume, but its there and there's random other shit in the exhaust that you probably don't want going through ur engine....think of it this way:
you have the choice of running PURE (as pure as you can get from our atmonsphere) air through your system with no additives or extra "shite"...or you can run some pure air mixed with random nasty shit that won't burn and will just take up space, maybe burn off some things that are bad for the enviro but not create any extra power, of course you have to lose a little power because there is less o2 burning, meaning less combustion, meaning less power
might not be noticable in the seat-o-the-pants dyno, but its gonna be there
secondly, the heat generated from egr would be inherintly bad....any extra heating of the engine/head is going to be a bad thing....
just my opinion but it makes sense....
Yes, one down side of the EGR system is heat soak in the intake. We are probably picking nits as to whether it makes much difference at all. It definitely reduces NOX emissions, and does little harm if it is functioning properly. I would leave it alone if it is in good repair, you are not going to gain much by removing it.
Thanks for the discussion, I appreciate this forum. We don't have to resort to flame wars just because we have differing opinions.
And that is something to be truly thankful for.
Love you guys a bunch, would do anything to help a fellow Supraholic.
You do displace some "normal air" with "inert gases". So you think that would make it run rich. But the ECU gets feedback from the O2 sensor so it adjusts the amount of fuel that gets injected to keep it stoichiometric. At least, this is true in closed loop mode (which is most of the driving you do). At WOT (wide open throttle), the ECU doesn't use O2 sensor feedback, but then again, at WOT the EGR is not recycling any exhaust gases either. A properly working EGR system only opens the EGR valve at part throttle, between 2500 to about 4500 rpms. Under any other conditions, EGR is not recycling any exhaust gases.
If the EGR is stealing power at WOT, then it is not working properly and should be fixed.
The EGR vavle is not a bad thing when it's working properly. It's like putting a brick in the toliet tank. So that less water comes in. Same thing with EGR vavles. They let recycled exhaust gas into the combustion camber. To where less air/fuel is let in. Thus making it burn less fuel and reducing combustion temps. Less fuel better fuel milage. Remember that it works off a vacuum switch. That does not let EGR gases in during idle or wide open throttle. So preformance is not effected when you need full power.
The problem is when it's not working right. Then performance suffers and so does gas mileage. In the good ole days. When our EGR's stopped work correctly. We just put a block off plate on them and said to hell with it. They cost too much to fix. Especially if the entire EGR system is plugged up with carbon build up. You'd have to tear the whole engine apart to clean all of the carbon build up out of the passeges.
If it's working ok then I'd leave it alone. If it's not then you pocket book will probly be your guide. On weather or not you want to fix it.
But don't sweat the EGR vavle. It's not a bad thing unless it's broke.
gases
what about the fact that if you are turbo, this puts hot air back in the combustion chamber... everyone knows that cold air=more horsepower.?? :twisted:
As compared to those N/a cars that aren't affected by air densities?
:scratch:
--BillyM
1 - 20 of 25 Posts
