1 - 3 of 3 Posts
Hello and please advise ....If I put Eibach springs -1" and KYB GR2s on my 85 MKll can I still fit 245/60/14 under her ???? With out rubbing ?? I know that I will have a rear camber problem.... unless someone knows how to fix that to.....???? :D
· Premium Member
if you haven't bought the tires yet then don't. A 245/60-14 has a noticably taller diameter then stock, you'd be better off going with a lower diameter. 245/50-14s work great and look pretty decent too. I had the 245/60s at one point and they looked a little silly they were so big and it was pretty close rubbing wise at stock height up front too.
I concur. I have seen a Supra lowered over 2" running the 245/50/14 BFGoodrich Comp T/A's. I almost lost my lunch when he took a sharp curve at 90!!!
1 - 3 of 3 Posts
