1 - 7 of 7 Posts
Look at your front strut rod bushings on the Corollas I used to run they were always shot. Upper strut mount too. If they are starting to dry rot, cracking or separating from the metal I never trusted them.
Energy Suspension DOES have the front sway bar FRAME mount sizes that you need!
1 1/8 ". Yes.Pick a diameter.
Hey BILLY_GTS, did you end up getting one of these kits? If so, which one? They look like the exact same product. Did you ever figure out which size Front Sway Bar Bushings to get?
I think that the OEM front bar is 24 MM. Please confirm.
Whitelines are 27 mm.
FRAME bushings.
1 - 7 of 7 Posts
