1 - 10 of 10 Posts
I'm doing a engine rebuild on my 85 supra with the 5mge. I was wondering if anyone knows the total advance for the stock motor. Please get back as to me as soon as you can that you guys
total advance?
Okay I'm sorry that I had messed up my first post but I know that the initial advance is 10 degree I just need to know the mechanical advance which is what I'm haveing problems trying to find
It is not a V-6 or V-8, you set the crank at "0" on #1 TDC and put everything together. The set the timing to "10" with a timing gun while the engine is running.
Its all up to the ECU. Unless you have 82 electronics in your 85 than its vacuum.
What is it you are trying to fix..
Are you having fuel cut too early.
He said he's rebuilding - I'm sure he's talking mechanical timing between crank and cams. Do as Chris says above.
persoanlly i would set timing at 10 on the crank at TDC and work from the dizzy thereafter
im running 13 degrees on the crank and then im about halfway on the distributer im running 93 octane to be safe
our motors seem to really like the advance in timing
1 - 10 of 10 Posts
