Ok, after I cleaned out inside the cat, the car runs much better for some reason (I did the same with the accord and no change). So I decide to take the distrubitor cap out and clean it too along with it's 2parts condenser (I think. they have magnet). I use w40 to clean the rust off where the rotor goes onto. I also adjusted the cables, trying to get rit of the slacks.
The engine runs, but weaker than before and the check engine kind of blinking several times. So I did the engine by pulling the plug wires one by one and found out that #3 cylinder make no change when I pulled. I check the wire (engine runs) it gives spark and spark plug sparks too. The injector sound normal.
So my question is What the hell wrong with it or did I do something wrong?
THNAKS!
THNAKS!
