Howdy, just picked up a MK2 that was supposedly garaged for quite some time, drove it home from two states away and the second I got home started seeing problem after problem. Anyway, right now when I drive it, if I put any actual load on the engine, it hesitates and wont rev. It will rev in neutral all day long to redline, but if I try to do say a third gear pull to 6 or even 5k rpm it simply wont. if I crack the throttle more than barely it wont rev under load. Recently replaced plugs, wires, ignition coil, igniter, oil, air filter. So after dealing with my ignition problems, perhaps she isnt getting fuel? Maybe the TPS is bad? Input appreciated. Thanks.
