1 - 3 of 3 Posts
I have a 2000 Audi A6 2.7T and recently the engine is not working right. after coming to a stop I will step on the gas and the gears wont get caught to turn the wheels. Instead the engine revs and the car rolls until the the wheels work. I am thinking this can be a transmission problem but I really dont know. Could it also be the timing belt?? please let me know if any of you encountered a problem like this before and if you solved it.
if it is standard then you need a new clutch if it is auto check the fluid!
In other words, no, it's not the timing belt and your description of the symptoms does not support your statement that the engine is not working right. As stated above, the clutch appears to be slipping if you have a manual gearbox, or if you have an automatic then it is the transmission itself that is the problem and the first thing to check would be the fluid level.
1 - 3 of 3 Posts
