1 - 20 of 37 Posts
Edit: After I tried a few picture hosters that did not work I edit all the posts again to get the pictures visible.
After I have almost completed my workshop and done all the necessary work on my other cars I have finally started taking my Supra apart for a complete restauration.
I have done some work before to keep it on the road and had a nice year to drive it in Sweden and Norway when I was working there. Underground Garage in Norway has done a great work on the suspension, now its time to get everything perfect!
So I started to take everything out and of course there is a lot of rust and dirt underneath
This weekend I am going to prepare everything to remove the engine, drivetrain and the axles.
Whistles
That's dedication. I love it!
Discussion Starter #5 (Edited)
where did you put all the parts? shelves are almost empty!
Good question!
I am a really messy person and tend to lose and forget a lot so i am forcing myself to clean up after work every time and I use a special sheme for storage.
The green shelf is only used temporary as long as i disassemble something. After I am finished it all gets in labeled bags and boxes and is stored in the larger shelves behind the car
Discussion Starter #6 (Edited)
I made some progress today. Before removing the rear axle I testfitted the wheels I intended to use.
Those are 3 piece 16x10 wheels from a C4 Corvette.
I have got an adapter set to fit the 5x120,x, but those adapters only work with bolts, not with the studs. So I will have to rethink it.
Anyway, they look great on the car and fit well in the rear:
Then I jacked her up, which was not easy because there is too much rust everywhere:
I removed the exhaust, fuel tank and the brakes. I tried to take the brake lines off the rearend but ended up just removing them together with it.
I have simply cut the brake and fuel lines because they will be replaced anyway:
A few minutes later it was done:
After I took the axle out I was glad that I always double secure a car when I jack it up. I couldnt put the stands further front because of the rust so it topped over a bit and was stopped from the rims underneath the front wheels:
Altogether it was a lot easier than I thought. The rust is far worse than I thought.
Sorry for the bad phone pictures, I had the camera with me but didnt upload them yet to my computer.
Discussion Starter #8 (Edited)
Now here are some more details.
The suspension was modified in Norway from the Underground Garage.
Maybe you know the blue crazy drifting X30 Cressida, that was done from the same guy.
It was a quite tight timeframe. The car was finished the night before I had to leave back to Austria, so there were some intermediate solutions because not everything fitted perfectly. Like the rear springs were too short, so he had to make a polyurethane spacer.
Although the time was so short and he had no time to test anything I had no troubles on my 1800km trip home and it drove really well.
That was two years ago and since then I got the workshop and will finish everything well now.
Unfortunately there was a lot of salt on the roads while I returned, and although I have washed it off later everything is in a quite bad condition after sitting for two years now.
So what has been done so far...
Custom made Coilovers with parts and springs from rallyeracing.com
Tokico HTS 102 adjustable dampers
Superpro Bushings
CNC milled rear strut adapter
T3 steering arms
T3 roll center adapters
Black diamond slotted discs (have not been installed in the rear due to the short time)
Ferodo Lotus Esprit Turbo performance pads
Cusco adjustable strut mounts front
Thats the actual status, everything will be taken apart, cleaned, repaired, zinc plated, ktl coated and powdercoated later.
The bushings still look like new, the sleeves move free and are not rusted at all
Thats the rear strut setup. The white PU spacer was just done to get the car back home, I will get longer springs later. The upper mount is CNC milled aluminium and is used to get the clearance between spring and body.
Nope. I can see your pics if I edit the page source and copy the link into its own browser, but it appears the direct image linking isn't working for me. Might be a firewall thing at work, but I rarely notice issues here.
Cross Member
Pictures aren't showing up for me either. If I bring up the browser console there are lots of errors complaining about an invalid SSL certificate. I can view each of the linked images if I change https to http.
Discussion Starter #14
I have seen worse cars getting back on the road, but yes its in a really bad shape.
Unfortunately there are only 8 supras registered anymore in my whole country. If any appear they are in a similar condition or crazy expensive.
Thanks a lot for the link! I have been following that restauration back then but couldnt find it anymore! Its a great Inspiration!
I wont do the bodywork on my own, i can weld and fabricate small brackets but it wont be well enough for the quality i want the Body to be. So i will have to spend some serious money for a restaurator, there are quite a few good people in my area.
Lol only 8 left in Austria! There were all in all 175 MA61s sold in Germany between 12/1981 and 12/1985! I know there are 7 in Bulgaria, 3 of them US imports.
I wish you all the strength, time and money to bring your restoration project to the end, it is a very serious undertaking! :thumbsup:
On the bright side, your car is in a very decent shape, compared to what I have seen! :naughty:
Discussion Starter #16 (Edited)
I can´t tell how many have been sold here in Austria, but it won´t be a lot.
In the typesheet of mine it says the date of the type approval for the MA61 is September 4th 1984! So they started selling the car later than that. Mine has the typesheet number 31 and was registered on January 2nd 1985.
I suppose the first batch of cars was delivered to the dealers as showcars and not ordered by customers. Mine was first registered to the owner of a Toyota dealer, so it could be one of that first batch.
As they started selling it just over a year before the MK3 was sold, I am sure there were far less than 100 cars sold.
I couldn´t get a lot done this weekend, I disassebled the rear axle. Surprisingly only two small bolts snapped off:
I was able to take everything apart, even the stub axles were quite easy to remove. But that large nut sits to tight and there is no space to get the right tools there.
The bushings came out really easy and I am glad I can reuse them:
Even the suspension frame bushings were easy to push out. The beam itself is in a great condition compared to the rest of the car:
Here is the pile of parts that I have collected so far. Everything except the brake disks fits to both the Supra and also my Crown:
Your car has rusted weird. It could be that it was only driven in the winter for a few years of its life, but the salt is doing a real number on the underside. Most mk2s I see with wheel wells like yours have massive holes in the exterior quarter panels too. Though the back half of your rocker panels look like they have been fixed previously.
Just keep in mind if you continue with this car and pay someone who knows what they are doing to resto it properly, the repair bill will be north of 10grand Cad\USD. We made that mistake with the LType in that restoration thread. We figured the couple grand we already had into the car plus the 5grand or so it would have cost to bring up a rust free car from the south end of the US wouldn't have made enough of a difference to bother, but we ended up spending 2x that fixing that car, and it is still not done yet. Also, we had donor metal from a rust free car to make it easier, including new wheel wells. You will have none of that if there are that few of them out your way.
Also, I see SuperPro subframe bushings but I don't see Raptor Racing's brackets for them (for the ones on the front subframe). If you don't have some, get some or make some (they aren't too hard to make). Without them, it is just that lip of Poly on the edge of the subframe bushings that holds your subframe to the car when you jack it up. The factory brackets don't work with the SuperPros.
Discussion Starter #18
I really apreciate your realistic view! Also that you have posted the link that I was so long searching for brought back a lot memories of the first repair and thoughts of how to continue.
The level of detail on your project is amazing! For me its even better than the mat.fi projects because they dont have any restrictions from time and resources.
Yes the car was always driven in winter. It was registered in January in Tyrol, quite in the center of the Alps, so I guess it has seen snow and salt from the first day on. And I also drove it for 4 winters, two of them in Sweden and Norway where they almost pave the roads with salt.
The first big work was done in 2011. I first hired a body professional who did a very bad job (as they just learn to cut out and reweld prefabricated parts today anymore). Later my best friend a carpenter took over. He has fabricated a lot of parts from metal sheets that looked like original and has the feeling for how to work with metal.
Unfortunately my backup harddrive failed some time ago and I dont have any pictures from that time anymore.
It was a huge work on the quarter panel, rockers, drivers door, around the fuel lid and much more. Almost everything that the first guy has done is rusted badly, but the stuff he has done is still in a quite good shape.
The bad thing is he is not the most reliable guy anymore so I wouldnt let him do such a huge project.
I cant work on the car for the next two weeks, so I will take the time, step back a bit and think about how to continue. You made me aware that a restaurer wont just fix what I can jugde to be bad on the car but probably will do the same detail as you did, and for that your number is set far too low i fear.
Discussion Starter #19
Today I started taking some exterior parts off and preparation to remove the engine.
I found some more rust, but nothing that I did not expect :)
So lets start, yes she is really dirty! Things will change. A quick before picture:
I expected that rust on the rear fender. all the areas that we fixed last time are solid, but everything we did not touch looks bad:
The wheel well is bad... Still solid in most areas but rusted really bad. We did not conserve it well...
The fenders look better than expected, only some surface rust in the lower areas:
I did not take a lot pictures while working, so thats the progress until now. Radiator, oil and powersteering coolers are out and the engine and trans are only connected to the subframe anymore.
It was quite easy to take everything off, except for the upper bumper nuts, I had to go and buy a long 10mm nut.
You can also see the badly rusted Hood. Ironically on the most rusty area there was a sticker once that the car was conserved when new and had 6 years rust guarantee :D
So lets take a look at all the stuff.
The front wheel well looks fine, but there is a lot of thick terpentine stuff in there, when this is removed I can see better how bad it really is.
The strut is as rusted as the rear struts but i tried to clean those and its just surface rust. I will have to find a way to conserve it.
The A-Pillars look bad. There will be a lot of work to do:
On the right side the radiator beam is rusty:
I dont think it was a leaking battery because the main beam looks fine. And its straight:
The other side also looks fine too, probably conserved by a leaking oil cooler line:
The crash beam also looks fine, at least from the whole picture it seems that it never had an accident:
A peak underneath the car. The main beam is very rusty in that area and the connection beam to the rocker is bent as the other three too. This also requires some work:
Tomorrow I have help and will lower the engine, trans and the front axle as one piece. Most of the preparation has been done, so it should just be the clutch cylinder and some bolts.
Discussion Starter #20
It took me 3 hours alone to get the engine out. Mostly because my help let me down and i dont have the proper tools for that.
Now I dont have free time to work on the car for a few weeks. The next step is to strip the body completely and then build a rotation frame to get better access to the underbody.
1 - 20 of 37 Posts
