1 - 3 of 3 Posts
So,i need to replacea bunch of fluids in my car, but the place i went to doesnt know what kind of stuff i need to buy, i have and 1984 supra (5m-GE, i think)
and i need new engine oil, brake fluid, transmission fluid what wieght? (standard), clutch fluid and differential fluid and what weight?
I usually run 10W40 oil. If its really cold you might want to go with 10w30 (below freezing) or 20w50 if its really hot (90+ consistently). Brake and Clutch fluid should be DOT 3 or 4. Differential and manual tranny oil should be 80w90 GL5. You should use limited slip additive in the diff if it a LSD (won't hurt if it isn't). Redline Mt90 in the tranny and Redline 75W90 Gear Oil is great stuff for the rear end and tranny if you want to swing the extra money (roughly $7 a quart). I have no clue what the Auto tranny stuff is :oops: . It Toyota type something though.
Aaron
82 A43DL's & SOME 83 A43DE Auto Tranny's use TYPE F. Check the owners manual for confirmation, or the TSRM.
84+ A43DE's use DEXRON II.
1 - 3 of 3 Posts
