Hello, so I've been trying to get my fog lights to work, I've already did the mod, checked the fuses, but still nothing, the only lights that will turn on are the small outer ones. Please lmk what else I could do or check!
Do they turn on with the headlights on?
Not calling you dumb, but are the bulbs burned out? Both of mine were burned out when I got my car. New bulbs and everything worked great now.
Did the fog lights work before the modification??
Also while you have bulbs pulled for testing, measure voltage at bulb connectors to verify power is actually getting there.
After checking it all, the bulbs work perfectly, power does go through, even after doing the mod. But nothing yet
That doesn't make sense:
1. when you apply external power to bulbs, they light.
2. measured and have power at bulb sockets
3. applying power from bulb sockets to bulbs doesn't light them
There's logic paradox here....
Yes, but the main fog lights aren't.
Aren't what? and what do you mean by the main fog lights - You have minor fog lights, too? Where?
And confirm which fog light modification did you perform?
I am sure you know this but the fog lights only come on when the headlights are on low beam.
Unless, of course, he did the mod that makes the fog lights independent from the headlights.
We need to know a little bit about what's going on here to help.
