1 - 17 of 17 Posts
Hello everyone! I know that I've been a little scarce (non-existent) on the forum lately. Just have a lot on the platter here at work and don't really get here all that much. I have been answering any and all emails that come to me and handle 100% of all inquiries and parts sales there. I just had to reduce the different mediums unto which I received communication from you all. Between CS.com, Facebook, email, and phones pulling me in all different directions I was starting to drop the ball and forget who I had talked to and who I didn't. I also needed to focus more time to the 'other' side of my job...you know...maintaining a busy metro area Toyota parts department with $500,000 inventory and 8 employees. :sarcasm: So...if you happen by this thread and wonder why I haven't answered your PM or thread...this is why. I'd be more than happy to handle all future inquiries and transactions via email. My email address is [email protected]. I don't filter my email...all of your inquiries come through the same account that I communicate with Toyota and all of our internal employees. I'll still take calls when available here at the store as well.
So...with that all cleared up...let me start by saying that these days are rough for MkII owners that need parts. We started to see this trend back when I started up on the forum as we burned through Toyota's on hand quantities of some old interior and exterior part numbers...part numbers that we said good bye to such as shift knobs, center console lids, defroster nozzles, tail lights, back door weatherstrips and mudguards. Than we had a little lull for awhile...everything stabilized, and we continued to order moldings like they were going out of style. Than last October we had the next wave begin...door belt moldings. RH rocker moldings. It seems like part numbers are starting to drop like flies weekly. I just found out last week that the 5MGE oil pan that was available all this time is now gone. An OIL PAN. :32:
So a few of you recently requested a 'available parts list' that I really didn't have, but thought...great idea! If anything it will be a quick reference sheet for me when I get an inquiry lol. Feel free to take a look and see if you have that nagging item that you've wanted to get but keep putting off. I don't want to create a panic at the disco...but I've heard a lot of guys tell me lately; 'coulda, shoulda, woulda' if they had any warning. (by the way...Toyota doesn't give me a warning...I usually find out one transaction too late like my current heater hose diabolical). For instance...you'll notice no heater hoses are on the list...yeah...'coulda, shoulda, woulda'. Tough pill to swallow eh?
I stock about 90% of these parts. I sell a part number off this sheet almost daily. Don't miss out...the crystal ball is far too murky for this guy to make out the end date for some of these numbers. The prices you see are Toyota MSRP and CS.com member price.
Celica Supra - Common Parts Request List
Underhood
74404-14260 Battery Clamp $19.51 $14.63
74451-14010 Battery Clamp 'J-bolt' $3.48 $2.61
90080-18071 Battery Clamp Nut $1.24 $0.93
91661-60616 Battery Clamp Bolt (core support side) $0.86 $0.65
74431-14040 Battery Tray $46.20 $34.65
53382-90K01 Hood Bumper (x4) $9.19 $6.89
88670-14050 Heater Control Valve $29.15 $21.86
88515-14080 A/C Expansion Valve $106.23 $79.27
88470-14010 A/C Reciever/Drier $62.88 $47.16
58151-34011 T100 Heat Shield (for Turbo Swaps) $46.20 $34.65
16267-43010 Coolant Bypass Hose (Suicide Hose) $18.39 $13.79
12262-43010 Crank Vent Hose (by oil cap) 82 $33.34 $25.01
12262-43020 Crank Vent Hose (by oil cap) 83-85 $60.36 $45.27
12261-43010 Vent Hose - Throttle Body $22.28 $16.71
17343-43020 Idle Up Hose - Front Right Valve Cover $10.86 $8.15
Rear Differential
90366-30078-77 Outer Pinion Bearing, RR Diff $45.43 $34.07
90366-35023-77 Inner Pinion Bearing, RR Diff $100.13 $75.10
90368-45002 Diff Carrier Bearing - Stock Diff (x2) $62.75 $47.06
90368-50006 Diff Carrier Bearing - TruTrac/TRD (x2) $45.40 $34.05
41231-22010 Diff Spacer (Crush Sleeve) $14.48 $10.86
90311-38010 Diff Pinion Seal $17.70 $13.28
90311-38011 Axle Seal, RR Diff (x2) $14.83 $11.12
90179-18001 Pinion Stake Nut $6.47 $4.85
Rear Wheel Bearings
90368-34083-77 Outer Bearing $52.16 $39.12
90366-30001 Inner Bearing $59.91 $44.93
90311-48001 Outer Seal $10.29 $7.72
90311-38009 Inner Seal $7.30 $5.48
42413-22010 Spacer (Crush Sleeve) $35.42 $26.57
90179-20061 Stake Nut $7.30 $5.48
Rear Suspension
48258-22041 Lower Rear Coil Spring Insulator, RH $16.58 $12.44
48258-22050 Lower Rear Coil Spring Insulator, LH $16.58 $12.44
Body/Trim
81219-14040 Turn Signal Lamp Bearing (socket clip) $1.67 $1.25
54125-14011 Protector, Retractor (Whiskers) RH $85.02 $63.77
54126-14011 Protector, Retractor (Whiskers) LH $85.02 $63.77
75531-14120 Windshield Molding, Top (incl. clips) $70.31 $52.73
75533-14160 Windshield Molding, RH (incl. clips) $68.96 $51.72
75534-14130 Windshield Molding, LH (incl. clips) $68.96 $51.72
75548-24020 Fastener, Windshield Molding (x9) $2.76 $2.07
69210-14070 Outer Door Handle (82-83), RH $105.85 $79.39
69220-14070 Outer Door Handle (82-83), LH $105.85 $79.39
69210-14080 Outer Door Handle (84-85), RH $108.21 $81.16
69220-14080* Outer Door Handle (84-85 CELICA), LH $105.85 $79.39
58808-14100-01 Shifter Leather boot, BLACK $66.95 $50.21
90179-05047 Insulated Nut - B-Pillar Trim (x2/side) $1.18 $0.89
67772-20021 B-Pillar Clip (x2) $1.18 $0.89
75671-14080 Belt Molding, Qtr Window RH $109.47 $82.10
75672-14080 Belt Molding, Qtr Window LH $109.47 $82.10
75791-14030 Belt Molding Clips (x8) $5.23 $3.92
63251-14020 Sliding Roof Weatherstrip $78.97 $59.23
62381-14090 Roof Rail Weatherstrip (top of side windows), RH $91.71 $68.78
62382-14090 Roof Rail Weatherstrip (top of side windows), LH $91.71 $68.78
67881-14110 Back Door Weatherstrip (MkIII part for MkII) $97.80 $73.35
75860-19145 Rocker Molding, LH (the RH is NLA don't ask) $168.72 $126.54
75731-14120 Body Side Molding, RH Front Door $116.48 $87.36
75732-14100 Body Side Molding, LH Front Door $116.48 $87.36
75651-14120 BSM, RH QTR Frnt (x2 for fender mod P-type) $44.51 $33.38
75652-14090 BSM, LH QTR Frnt (x2 for fender mod P-type) $44.51 $33.38
75653-14100 BSM, RH QTR Rear (x2 for fender mod P-type) $60.91 $45.68
75654-14090 BSM, LH QTR Rear (x2 for fender mod P-type) $60.91 $45.68
*this handle will fit a Supra, but there is no provision for the key light on the 85 models with theft deterrent
Electrical
84312-20011 Horn Contact Plate (fits Denso combo switches) $6.78 $5.09
81730-19306 RH Front Side Marker 82-83 $28.24 $21.18
81740-19286 LH Front Side Marker 82-83 $28.24 $21.18
Information is subject to change, last update 03.05.2013
Hope to hear from you! Happy motorin'!!
Great to see you back! How's your car doing these days after that unfortunate accident... I enjoy watching your 2JZ videos on youtube... LOL.
not sure if u remember me but i have been trying to reach the illusive unicorn (you) for a while. I am paolo from honolulu hawaii and i have been calling and emailing. sorry if i am bothering u but in hawaii, i cant find parts for [email protected] im glad u have freed up a little to make room for us to order some parts and with an awesome discount.
I am in need
pm sent
Guys, please read carefully.
Mark asked for inquiries to be via email at [email protected]
He spent lots of time putting this list up, so please don't overlook the instructions !
PS: Glad you showed up. You are missed here.
Discussion Starter #11
i sent it threw email pm and here. i tried to reach him about 50 times threw email and call and get nothing. im just maximizing my chance for him to notice me..... so yeah....
Paolo,
You are definitely one of the dropped balls I was referring to in my initial post. I will be in contact with you via email tomorrow morning. Guys and gals... please understand that my role in the store does not allow for me to babysit a phone sitting at a desk all day long. Our dealership is on 7.5 acres of land encompassing four buildings. I'm on the move all day long... So my guys on the phones tend to screen from time to time.
Hey, i sent you an email the other week. Im not sure if the parts I listed are NLA, but im still keen on the ones from the start of this thread. racsov500 @ hotmail.com
1 - 17 of 17 Posts
