1 - 20 of 26 Posts
1985 Toyota Supra w/ modified 6MGE and 5 speed swap
Contact Information
Email: [email protected]
Asking Price: $2,800 FIRM (price is NOT up for discussion!)
Performance upgrades:
Rebuilt 6MGE block
Rotating assembly fully balanced
Bored .030" over with high compression pistons
Early 5M head with late 5M cams/towers
HKS 1.2mm metal head gasket
ARP head studs
Rare TRUST header, ceramic coated & modified with wideband O2 bung
RabidChimp 2.5" Collector
RabidChimp 2.5" Catback
Magnaflow muffler
RabidChimp ceramic coated intake
RabidChimp CAI
NGK spark plug wires
6MGE intake manifold
6MGE M/T ECU
Walbro 255lph fuel pump
Exterior Modifications:
JDM rear marker vents modified with lights
DJs custom clear turn signals
Tinted tail lights
Tinted nose badge & B pillar badges
JDM 3.0 TwinCam badge from MZ12 Soarer
Known Issues:
All air conditioning components removed
All HVAC, wiring, relays removed
Power steering removed
Cruise control removed
Washer fluid tank removed
Sheetmetal under battery tray needs replaced
Rack 'n pinion leaks, lines are looped
Car is lowered by a previous owner heating the springs
Body has numerous dings
Airdam is severely cracked
Driver's door was damaged, and poorly repaired with bondo by a previous owner
Very long key scratch down passengers side
Bad repaint, trim painted over, some areas bubbling up
Some rust on the inside of the hatch
Rust holes in spare tire well
Dashboard is cracked
Passenger's inner door panel needs repair
Rear windshield wiper doesn't work
No spare tire/wheel
Power mirrors do not work
Ghetto tint peeling on passenger's side
Uses 7MGE crank pulley, alternator belt is finicky
Clutch pedal needs upper support still
Gets 18-21mpg, probably due to the fuel pump and J tube bypass
Broken antenna
No radio
Other:
The car was dynoed, but I did not have it at WOT :rolleyes: The results were 155hp and 175ft/lbs on a DynoJet. Probably a few more ponies on a proper dyno pull.
http://i160.photobucket.com/albums/t187/celicasupragirl/Black85/6M Build/IMG_2960.jpg
The car was also taken to the quarter mile, but only ran once and ran 15.5 @ 88mph with a whole lot of tire spin. Definitely has the potential for 14s when hooked.
http://tinypic.com/player.php?v=29pxbpj&s=3
Pictures:
Discussion Starter #5
Long story..... You'll have to ask both parties for a explanation....
Basically..... Car & previous owner are now on opposite ends of the US. Keeping the motor is not an option right now.
Discussion Starter #9
Car and current owner, you mean ;)
The car is mine, the title is in my name. The title is in Washington, signed and waiting for a new owner.
Circumstances in life have made it impossible for me to have the car, and no further explanation is needed for anyone.
Damn too bad you weren't selling this when I was looking :mad: . Oh well too bad your selling her. She's a really nice car.
Damn T that sucks that you're selling your Mkii. You put alot of work into it. Hope you get another one when you can.
Wish I had the $$$. Problem is, I'd part it, or put a stock 5m in it and resell. Black Cars FTMFL !!!
Discussion Starter #18
Epic fail. I've had someone else tell me they would rape the drivetrain out of her. Reading stuff like that makes me sad and sick to my stomache. :sadsmilie
I'm not sorry T ;) I'd rape that beast in a heartbeat.
It's funny you brought up that point, because the first thing I thought when I read this thread was "that would be a awesomely cheap 6m swap in my SDR, and it would make another 5m blackpra to sell!"
No offense though (I would rather not make you sick to your stomach), I just like red a little better.
Good luck with the sale. Maybe if these opportunities arose on the east coast they would sell faster. :)
-Forrest
1 - 20 of 26 Posts
