Without the extra air from the turbo the mk3 turbo injectors will put in way to much gas. Your car will pour out black smoke and your fuel mileage will drop waaaay down and you will not get more power.supraii said:Hi, I have the mkiii turbo injectors. My 85 mkii is not turbo. If I decide put the mkiii turbo injectors in it, will my mkii get any benefit from this?
thanks!
You can't even hook up those injectors without a standalone or some serious rewiring. Its the non turbo mk3 injectors that can be used on our cars. One is low impedenace, the other high, can't remember which is which but you can't mix and match the two without some electronic tinkering.supraii said:Hi, I have the mkiii turbo injectors. My 85 mkii is not turbo. If I decide put the mkiii turbo injectors in it, will my mkii get any benefit from this?
thanks!
SupraFiend said:supraii said:One is low impedenace, the other high, can't remember which is which but you can't mix and match the two without some electronic tinkering.
All the injectors I listed above are low impedance...including the non turbo MK3 295s.
