1 - 3 of 3 Posts
Myself and 3 friends are trying to fix my '82; where the fuck is the fuel pump relay?
There are 2 relays that control the fuel pump. One is the Main Relay #1 in the fuse block in the engine bay, and the other one is the Circuit Opening Relay behind the drivers side kick panel (you actually have to take the panel off to get to it), it will be the green relay on the bottom right corner, there is a 10mm bolt right above it that the mount goes to.
Have you tried jumpering the fuel pump test connector (with a paper clip, or an expensive Toyota equivalent - plus the key needs to be on)?
Also, Sowsley has specific 82 info here, if you haven't seen it (vacuum and engine controls significantly different).
1 - 3 of 3 Posts
